You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.1 (812) English
Posted by: pspad | Date: 2023-12-01 11:25 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
f57aa714357e5a5de973e79796131328c11f22b4 pspad551b812.zip
a46c55642ed0f4a2f81fa335d6e7ebd67daf138e pspad551b812x64.zip
Changes to 5.5.1 (790)
News:
Compiled in Delphi 12
Added YAML support
Accesibility support - PSPad fully supports screen readers such as Windows Narrator and NVDA
Clipboard monitor (Alt+M) - possibility to change items order with Drag/Drop, possibility to select all items with Shift+Ctrl+A or toolbar button or context menu
HTML highlighter - added highlighting of the pair tag PRE
New bookmarks functions in the menu Search - Copy lines with bookmarks and Delete lines without Bookmarks
Windows Shell Script highlighter - keywords revision
OpenSSL libraries updated to 3.20 version
UseClearType (available in Settings Direct edit) doesn't require program restart
Font change (menu Format/Font) accepts UseClearType parameter without program restart
Recent file list wasn't updated when you close application with cross ikon
Handled state when Log window height was higher than main window height
Other fixes reported by users
Posted by: Piotr | Date: 2023-12-04 12:43 | IP: IP Logged
CTRL + Del
It used to be possible (but I don't know which version) to delete subsequent lines of the document.
Now spaces/words up to the last word in the line are removed, e.g.
charset=utf-8"> --> ">
www.pspad.com --> com
It was already discussed here: forum.pspad.com
Posted by: pspad | Date: 2023-12-04 13:54 | IP: IP Logged
I just tested and there is no change. in case of www.pspad.com it behaves:
www.pspad.com
.pspad.com
pspad.com
.com
com
or do you mean the last part isn't removed?
Edited 1 time(s). Last edit at 2023-12-04 13:56 by pspad.
Posted by: Piotr | Date: 2023-12-05 08:57 | IP: IP Logged
Quote:or do you mean the last part isn't removed?
Yes
After removing the last element, another line should be inserted.
This is how it worked...
Thanks!
Posted by: Freeman | Date: 2023-12-09 13:25 | IP: IP Logged
This build doesn't restore opened files on next run. Build 790 does (just replaced exe file for the rollback).
Also can't translate cAutoSaveLostFocus_Caption “Automaticky uložit soubory (mimo nových) při deaktivaci programu” in build 790, either in English or Russian. Still not translated in 812.
Edited 1 time(s). Last edit at 2023-12-09 13:32 by Freeman.
Posted by: DelphiErik | Date: 2023-12-13 20:01 | IP: IP Logged
Hi, in dark mode (IDE style: Windows 10 Office Dark2) the background of the Toolbar is now white. In build 790 this was correctly dark. In build 812 it's not correct (white). See image/link:
Posted by: pspad | Date: 2023-12-13 20:20 | IP: IP Logged
DelphiErik:Hi, in dark mode (IDE style: Windows 10 Office Dark2) the background of the Toolbar is now white. In build 790 this was correctly dark. In build 812 it's not correct (white). See image/link:
New Delphi version, some things were changed. I will handle it somehow.
Posted by: Joel | Date: 2024-01-04 22:39 | IP: IP Logged
Settings > Program (part1) > Menu icon set and Toolbar icon set only has options for PSPad and PSPad24. Is this intentional?
Are there other settings or features that this version doesn't have?
Posted by: pspad | Date: 2024-01-05 05:04 | IP: IP Logged
This is a icon size for toolbar and menu.
Names are taken automaticalky from the skin subfolder. When you create new iconset and put it into folder, it will apoear in the settings
Developer version contains changed files only. Do if you have 2 iconpack there only,unpack full version first and replace it with content of developer version package. See description in ane developer build topic
Edited 1 time(s). Last edit at 2024-01-05 05:07 by pspad.
Posted by: Ravelli | Date: 2024-01-16 17:56 | IP: IP Logged
One of my PHP scripts wasn't working today. Turned out there is a mojibake "ÿ..." in the file. It probably happened during a PSPad crash the other day. I will send you the PHP file via email.
