You are here: PSPad forum > English discussion forum > Fails using CTRL+Del
Posted by: Marcos | Date: 2023-05-17 23:02 | IP: IP Logged
on a line that contains several spaces and then a word. I would like to use CTRL+DEL to delete the spaces until the next word. when I use CTRL+DEL the editor deletes the cursor spaces forward including the next word. I would like you to delete only the spaces.
Example:
01 test
in this line I have 10 spaces + the text "01 test"
if at the beginning of the line I use CTRL+Del the PSPAD erases the forward cursor spaces and the text "01 "
This worked perfectly until version 4.5.7 (2450). After I updated to version 5.0.7 (731) it stopped working.
Posted by: pspad | Date: 2023-05-18 03:12 | IP: IP Logged
Why don't you use Del to delete one space or one char?
Posted by: Marcos | Date: 2023-05-18 13:15 | IP: IP Logged
hello,
Precisely because I want to delete all the spaces until the beginning of the next word.
Remembering that in version 4.5.7 it worked perfectly. Only after updating it stopped working.
I looked for some configuration, but I didn't find anything about it.
Marcos Alija Ramos
Posted by: pspad | Date: 2023-05-21 14:05 | IP: IP Logged
OK. It should behave that forst it deletes all spaces and next it will delete word e.t.c. right?
Posted by: Marcos | Date: 2023-05-22 14:52 | IP: IP Logged
Exactly.
The correct is:
By pressing CTRL+Del, delete all spaces from the cursor until the next word.
If you click CTRL+Del again, then delete the next word.
Remembering that in version 4.5.7 (2450) it already worked that way.
Marcos Alija Ramos
Brazil.
Posted by: pspad | Date: 2023-06-05 08:36 | IP: IP Logged
Next developer build will contains fix
Posted by: Marcos | Date: 2023-06-05 19:56 | IP: IP Logged
Wonder,
I'll wait for the version to test.
Once I test it, I'll give you feedback.
Thank you very much.
Posted by: Marcos | Date: 2023-06-16 22:07 | IP: IP Logged
I downloaded the latest developer version.
It looks great.
Only one detail remains. On a line that contains several words. When CTRL+Del is clicked, the pspad editor deletes the word under the cursor (Perfect and correct). Only the last word of the line he does not erase. (It should delete, just like in previous versions). If you manage to correct this detail, it will be excellent.
Even so, as it is, it turned out pretty good.
Another thing. I'm trying to make a donation using a credit card, but I can't. It is asking me for PayPal account details and to open a PayPal account. I don't have a PayPal account and I wouldn't want to open one either.
Is there a way to make this donation using only the credit card ??
Congratulations on the work done with the PSPad. An excellent tool.
And thank you very much for your attention.
Marcos Alija Ramos
Brazil
