You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.2 (2228) English
Goto Page: 1 2 3 4 5 6 7 8 9 Next
Posted by: pspad | Date: 2006-07-06 13:51 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.2 (2227)
News
dblclick on the file tab closes file
missing words added into VB highlighter
modified JavaScript preview in the internal HTML brovser - wrapper depends of the HTML or XHTML setting in the multihighlighter
addded VBScript preview in the internal HTML preview
Corrections
file context handler (problem was in the PSPad not in the handler)
file information - last word in the file was missing
FTP client - list of files from IBM mainframe (MVS)
new text file doesn't highlight URLs
Text differences - highlighting
problems with the PSCache.bin file version
Context menu handler update
1. close Windows Explorer, Total Commander e.t.c.
2. run PSPad, go to the Program settings / System and uncheck [x]Integrate with a Right mouse click
3. close PSPad
4. open Explorer (Total Commander, ...) and replace PSPadShell.DLL with a new one
5. run PSPad and activate option in the Program settings / System
Posted by: tangouli | Date: 2006-07-06 14:27 | IP: IP Logged
Hi Jan,
thank you for this new version!
Its a small change but a great one for usability: closing files by doubleclick in tab!
Ulrich Heiwolt
Posted by: Yuval | Date: 2006-07-06 15:26 | IP: IP Logged
Wow, you did it - dblclick closes tabs!!!
Thank you so much,
- Yuval.
Posted by: pjj | Date: 2006-07-06 16:28 | IP: IP Logged
Ooops, seems that reordering tabs with drag'n'drop ceased to work
Posted by: Nelson | Date: 2006-07-06 17:25 | IP: IP Logged
pspad:Corrections
Hello, can somebody explain this?
What's the problem in the previous version?
Posted by: pspad | Date: 2006-07-06 17:59 | IP: IP Logged
Nelson:Hello, can somebody explain this?
If you open several files with Logn file names and PSPad was running, some file was open incorrectly
Posted by: pspad | Date: 2006-07-06 18:01 | IP: IP Logged
pjj:Ooops, seems that reordering tabs with drag'n'drop ceased to work![]()
My fault. Corrected. Download this build again.
Posted by: Lolo | Date: 2006-07-06 19:38 | IP: IP Logged
Hi Jan,
Thank you very much for this new version!
Long life to PSPad !!!
Posted by: Reissom | Date: 2006-07-06 21:21 | IP: IP Logged
I still have a problem with Context menu handler.
The "Send To" menu takes about 15 seconds to display in WinXP explorer.
Also you mention to replace PSPadShell.DLL with a new one, I did not have one to begin with but is location for the DLL the same as the PSPad home directory.
Thanks,
Reissom
Posted by: Jody | Date: 2006-07-06 21:30 | IP: IP Logged
Thank you so much for the dbl-click close tab. I've waited so long for this and thought it would never happen.
I knew it would give you a problem with reordering tabs but you figured that out.
Jan, you are definitely the man !
Thanks again !!!
Jody
Edited 1 time(s). Last edit at 2006-07-06 21:36 by Jody.
