You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2331) English
Goto Page: Previous1 2 3 4 5 6 7 8 9 Next
#71 Re: PSPad unicode 4.5.4 (2331) English
Posted by: thomas | Date: 2008-11-18 18:37 | IP: IP Logged
I don't agree. I am open files with tens of MB in seconds.
If file contains very long lines (tausands of chars), it can slow down PSpad.
Can you send me some of your file packed to support mail if it isn't confidental or private?
Try this:
Program settings / Editor
enable Scroll past EOL
Well, I have that option turned off, but it still takes ages to load big files.
Loading a 2MB textfile with PSPad takes about 30seconds while the CPU is at 100% (luckily I have two of them..)
Doing the same with Textpad or PNotepad, I can't even stop the time it takes to load the file (Textpad and the file are loaded in around a second)
#72 Re: PSPad unicode 4.5.4 (2331) English
Posted by: pspad | Date: 2008-11-18 18:53 | IP: IP Logged
thomas:
Can you send me some of your file packed to support mail?
E.g. 103MB TXT file my PSpad include it's start opens in 3s
Edited 1 time(s). Last edit at 2008-11-18 18:53 by pspad.
#73 Re: PSPad unicode 4.5.4 (2331) English
Posted by: thomas | Date: 2008-11-18 19:29 | IP: IP Logged
While trying again, I noticed that sometimes it is indeed quite fast (although still not as fast as PNotepad or Textpad)
As far as I can tell this is related to the Code Explorer panel (that I usually have open). Even for txt files (that don't display anything the code explorer) it is then extremely slow, but also for .sql files (that don't display anything as well).
But still it's unusable on large XML files when the code explorer is opened (which is a shame because the code explorer for XML files is one of the reasons I stick to PSPad)
#74 Re: PSPad unicode 4.5.4 (2331) English
Posted by: pspad | Date: 2008-11-18 19:37 | IP: IP Logged
Code explorer needs to parse file. It takes some time.
Maybe I add some file size limit to automatically parse file in code explorer
#75 Re: PSPad unicode 4.5.4 (2331) English
Posted by: thomas | Date: 2008-11-18 20:09 | IP: IP Logged
But it shouldn't do that for files that aren't supported anyway.
For text files the code explorer simply displays "Not supported for this type" so why is the file "parsed"?
#76 Re: PSPad unicode 4.5.4 (2331) English
Posted by: pspad | Date: 2008-11-18 20:34 | IP: IP Logged
thomas:
Sorry, but you wrote about large XML files.
For TXT files PSPad doesn't parse anything.
Switch off Code explorer panel and test your XML files.
In the next build I will you possibility to set file size limit for automatical parsing
#77 Re: PSPad unicode 4.5.4 (2331) English
Posted by: thomas | Date: 2008-11-18 20:44 | IP: IP Logged
I wrote about txt, sql and XML
For XML I can understand that the code explorer slows down retrieval, but not for txt (or SQL)
#78 Re: PSPad unicode 4.5.4 (2331) English
Posted by: pspad | Date: 2008-11-18 20:50 | IP: IP Logged
SQL is parsed too
As I wrote you, I open 103MB file include PSPad start in 3s on my about 2 years old notebook.
I don't know nothing about your system. What takes a long time? PSPad start or open file in running PSpad?
#79 Re: PSPad unicode 4.5.4 (2331) English
Posted by: thomas | Date: 2008-11-18 21:01 | IP: IP Logged
Opening the file. Starting PSPad takes about 1 second.
Both systems are about 2 years old as well (2GB RAM each)
#80 Re: PSPad unicode 4.5.4 (2331) English
Posted by: wjjchess | Date: 2008-11-19 00:35 | IP: IP Logged
thomas:
Try this:
You are wrong, If you want open file fast,It must The Option been turn on.
