You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2331) English
Goto Page: Previous1 2 3 4 5 6 7 8 9 Next
#51 Re: PSPad unicode 4.5.4 (2331) English
Posted by: jruv | Date: 2008-10-21 03:16 | IP: IP Logged
New Bug??
My "Show Clips" will not work on syntax file such as XML/C/C++. It works only for *.txt file. Anybody has the same problem with me?
Edited 1 time(s). Last edit at 2008-10-21 03:16 by jruv.
#52 Re: PSPad unicode 4.5.4 (2331) English
Posted by: jruv | Date: 2008-10-21 03:21 | IP: IP Logged
jruv:
New Bug??
Oh, it because my clip was created from *.txt.
Is there a way to create a clip which can be applied to any type file?
#53 Re: PSPad unicode 4.5.4 (2331) English
Posted by: pspad | Date: 2008-10-21 04:59 | IP: IP Logged
No. Clip is related to highlighter
But you can switch off syntax highight (button on toolbar) and then used your TXT clips
#54 Re: PSPad unicode 4.5.4 (2331) English
Posted by: arek1 | Date: 2008-10-21 07:44 | IP: IP Logged
I was creating HTML file and after switching off View->Syntax my TXT clips still not working in HTML or XHTML file.
What I am doing wrong?
Best wishes
Arek
#55 Re: PSPad unicode 4.5.4 (2331) English
Posted by: pspad | Date: 2008-10-21 08:11 | IP: IP Logged
arek1:
Best wishes
Arek
Program settings / Direct edit
Change value of variable:
TextClipsIfHLOff=1
#56 Re: PSPad unicode 4.5.4 (2331) English
Posted by: arek1 | Date: 2008-10-21 10:25 | IP: IP Logged
Thank You,
Now it working very well.
Best wishes
Arek S
#57 Re: PSPad unicode 4.5.4 (2331) English
Posted by: Joël | Date: 2008-10-22 06:56 | IP: IP Logged
I tried, but the crash still appears. It does not seem to depend on if right edge is present or not and on if wrapping is done with respect to the right edge or to the window edge. Also it does not depend on the value of max line length.
#58 Re: PSPad unicode 4.5.4 (2331) English
Posted by: Thralia | Date: 2008-10-22 07:20 | IP: IP Logged
I don't know if this bug has already been reported, but I have some trouble with the syntax color chooser. Here come some screenshots :
New document :
Change syntax color on existing document :
As you can see, when I create a new document and want to change the syntax coloring, the "TXT file" entry is gone with the wind ...
HTH,
Thralia
#59 Re: PSPad unicode 4.5.4 (2331) English
Posted by: pspad | Date: 2008-10-22 07:38 | IP: IP Logged
Thralia:
TXT file has no syntax. You can switch off syntax of any file with button on toolbar or in the menu View
#60 Re: PSPad unicode 4.5.4 (2331) English
Posted by: microalps | Date: 2008-10-30 16:50 | IP: IP Logged
There is a serious error in your latest build that causes tabs to get confused resulting in files saving over other (open) files (in another tab). This has occurred more than once -- the first time cost me several hours to rewrite the files that were overwritten. I have attached screenshots of the visible result of this bug -- the tab says one name but the hover over says another.
