You are here: PSPad forum > Bug report / Hlášení chyb > Re: Many Crash, Many strange symbols ÿ
Posted by: LouCypher | Date: 2022-12-08 08:59 | IP: IP Logged
I know this. I just wanted to point to this option as a possible cause for the injected garbage data which you cannot reproduce.
Posted by: rseibel | Date: 2022-12-08 10:07 | IP: IP Logged
Problem occurs in other editor tabs without doing anything.
Switched just in the moment to a second tab to change something,
went back to first tab an my text has changed (.... = 1 TAB Hex 09):
CASE KEY9
....// Langtexte
....IF PROC POS_Current ()
........IF PROC s_langtext.textObjAuswahl (O_PREISLISTE, vk_preislisten.pl_nr, "", PROC s_langtext.getEditModus("")) END
ÿ EN
........CONTINUE
....CASE KEY10
'END' was replaced with HEX-Codes: FF 00 45 4E
Occurs for me always at line ends, then following CR LF = 10 0A ...
Perhaps important: Tabs (HEX 09) in front of this erroneous replacements are always gone/deleted.
Good luck
Edited 4 time(s). Last edit at 2022-12-08 10:11 by rseibel.
Posted by: rseibel | Date: 2023-01-19 10:27 | IP: IP Logged
I try every new beta (always 32 bit), but this errors never disappear.
For me this is the most important point to use pspad further on.
Some time ago i donated for this editor, i love it,
but working with it gets more and more frustrating.
I hope that you are able to have a special look into this errors.
Regards
Roger
