You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.3 (365) English
Posted by: pspad | Date: 2020-01-16 21:42 | IP: IP Logged
Download links (5.4 MB):
Changes to 5.0.3 (363)
News:
Find in files dialog was changed from modal to normal. It allows let dialog open and edit files together
Favourite window contains new section - script. You can add script there by selecting from drop down list
User highlighter definition - added block comment for Autoit3 - #cs ... #ce
New PSPad command line parameter /F or /FR (as alternative -F or -FR) will start search on open file. /F for normal search, /FR for search with regular expressions. Syntax: pspad "path\file" /F "search expression"
PSPad remembers column with of Name, size and modified for File explorer and FTP
User friendly message when you try compare file with selected file from disk in case both files has different encoding
Insert text to lines - added "Apply" button, so you can use this function several times without leaving dialog
handled exception when several PSPad instances was closed at once and all instances write file state in same time
when PSpad was set as StayOnTop, Program settings appear behind the main window
Program Settings / KeyMap - problem drawing with scrollbar (only some group and languages)
if main PSPad window was maximized, minimized and open file from outside, PSPad wasn't restored as maximized
ASCII chart wasn't translated after language change
Python highlighter - search for matching bracket if bracket was in string
Highlighting URL in text doesn't respect two dots - something..html
Posted by: MadCompie | Date: 2020-01-17 17:47 | IP: IP Logged
Hi Jan, love the new FTP grouping!
I have some questions about this new functionality:
1) duplicate doesn't work anymore (ex. duplicatie "ABC" to "kljsfdsgh" results in error that "kljsfdsgh" already exists
2) grouping is only visible while editing the FTP entries. Could it be possible to group it also in the pop-up (with all FTP entries) that appears after pressing the little arrow button?
Posted by: pspad | Date: 2020-01-17 22:25 | IP: IP Logged
Duplicates was disabled before too.
You can't have two connection with same name.
Posted by: MadCompie | Date: 2020-01-20 09:15 | IP: IP Logged
But it is a different name?
Ex. "kljsfdsgh" is a randomly generated name that does not exist yet in the list...
Posted by: pspad | Date: 2020-01-20 09:32 | IP: IP Logged
MadCompie:But it is a different name?
Please write step by step how to get this message.
Only connection name must be unique.
Posted by: MadCompie | Date: 2020-01-20 12:14 | IP: IP Logged
Hello, here a step-by-step example:
1) open ftp edit popup
2) select existing connection "A"
3) click button "duplicate"
4) enter a random name "ABCDEFG"
5) error message!
Posted by: pspad | Date: 2020-01-20 13:31 | IP: IP Logged
Tested, but I can't reproduce it.
I selected connection with name "test". I clicked Duplicate, write ljdsafha, press Enter and new connection with ljdsafha name was created.
Ahhh. I see. The problem is if the connection isn't in the folder. If the connection is in root, I can reproduce it. I will fix it.
Posted by: pspad | Date: 2020-01-20 13:51 | IP: IP Logged
Change. it was working for the first time. But if you connect or cpy first connection, try of copy another ends with this message.
Fixed, wait for next build
Posted by: MadCompie | Date: 2020-01-20 20:05 | IP: IP Logged
Perfect!
