You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2246) English
Posted by: pspad | Date: 2006-11-20 20:19 | IP: IP Logged
Strange. Try rename dictionary to English.DIC and set it in the Spell setings (Ctr+F7)
Posted by: JollyRoger | Date: 2006-11-20 20:26 | IP: IP Logged
Done. Still the same.
Update: Checked with 2244. Works.
Edited 1 time(s). Last edit at 2006-11-20 20:28 by JollyRoger.
Posted by: PGomersall | Date: 2006-11-20 20:54 | IP: IP Logged
There still seems to be the bug of overwritten characters in the output window.
After first compilation characters are correctly written; all subsequent compilations produce the overwritten characters as in this post: forum.pspad.com
Pete
Posted by: Stealth | Date: 2006-11-20 21:02 | IP: IP Logged
Jan,
thank again for html template support (aka smarty..), but there is a bug...
Try the follow peace of code:
{if $paginate}
<Table width="70%" ALIGN="CENTER" border="0">
<TR>
<TD align="center">
{foreach item=element from=$page}
{if $element.p_corr == $p_corr}
<span class="tb">{$element.p_corr}</span>
{else}
<span><A href="#" onclick="show('{$element.p_corr}', '{$element.offset}', '{$element.limit}'); return false;">{$element.p_corr}</a></span>
{/if}
{/foreach}
</TD>
</TR>
</TABLE>
{/if}
There's no colorize in{if $paginate}
and in the final{/if}
for example...
Posted by: Dave | Date: 2006-11-20 21:29 | IP: IP Logged
I get the same problem with the English dictionary. The problem does appear to have started in this latest version.
Posted by: pspad | Date: 2006-11-20 21:47 | IP: IP Logged
Stealth:There's no colorize in{if $paginate}
for example...
Posted by: Stealth | Date: 2006-11-20 22:03 | IP: IP Logged
If you tab{if $paginate}
you will see the problem
Posted by: Stealth | Date: 2006-11-20 22:20 | IP: IP Logged
My settings is real tabs not checked and smart tabs not checked.
If i use real tabs checked, the problem is solved.
May you fix the real tabs not checked case?
Posted by: pspad | Date: 2006-11-20 22:21 | IP: IP Logged
I put real tab before {if $paginate} and no change.
Still highlighted OK.
Posted by: Stealth | Date: 2006-11-20 22:35 | IP: IP Logged
pspad:I put real tab before {if $paginate} and no change.
Yes, if i put real tab highlighted is ok, but if real tabs is unchecked highlighted isn't ok.
I will use real tabs checked in my html templates
