You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2246) English
Posted by: carbonize | Date: 2006-11-21 15:09 | IP: IP Logged
pspad:carbonize:Minor bug but if you use F2 to show toolbar, then Ctrl + F2 to show Tool Panel and then do Ctrl + F2 again to hide it F2 no longer works for hiding/showing the toolbar.If Project panel is focused, F2 is used to start rename project item. In any other case F2 shows you Toolbar
Yes but after you close the tool panel F2 no longer shows/hides the toolbar.
Carbonize
Posted by: pspad | Date: 2006-11-21 15:42 | IP: IP Logged
DT:When you click on it to change the selection type, you can select text in different ways, but the icon remains the same.
Worked before...
Thanks,
DT
Thank you for the info
Posted by: pspad | Date: 2006-11-21 15:59 | IP: IP Logged
JollyRoger:Jan, I needed to get the coordinates, not to set them.
There must have been a missunderstanding. I specifically requested more information, not more control. Maybe I'm missing something?
I am sorry.
Posted by: MrSpock | Date: 2006-11-21 16:07 | IP: IP Logged
Pierre.Brico:Hi Jan,Concerning the "Dictionary English.2-1-0 not found" problem, it seems that PSPad now looks for its dictionary in "C:\program files\Common files\SynSpell". If I copy the content of PSPad spell directory there, PSPad's Spell Check works again.
Regards,
Pierre
Looks like this is even hard-coded for some reason. On my machine there is no folder "c:\program files\", but the same query takes place.
Posted by: JollyRoger | Date: 2006-11-21 16:14 | IP: IP Logged
pspad:JollyRoger:Jan, I needed to get the coordinates, not to set them.
There must have been a missunderstanding. I specifically requested more information, not more control. Maybe I'm missing something?I am sorry.
Please don't be. I understand very well that bug fixing comes first. We can settle this later, and in any case there's no need to appologize. Missunderstandings happen all the time.
Posted by: pspad | Date: 2006-11-21 16:57 | IP: IP Logged
carbonize:Yes but after you close the tool panel F2 no longer shows/hides the toolbar.
Please step by step sequence. I am not able to simulate it.
Posted by: pspad | Date: 2006-11-21 17:42 | IP: IP Logged
Pierre.Brico:Hi Jan,Concerning the ""Dictionary English.2-1-0 not found" problem, it seems that PSPad now looks for its dictionary in "C:\program files\Common files\SynSpell". If I copy the content of PSPad spell directory there, PSPad's Spell Check works again.
Regards,
Pierre
Do you have access to your profile ?
Check if exists system variable %userprofile%.
Posted by: MrSpock | Date: 2006-11-21 18:34 | IP: IP Logged
pspad:Do you have access to your profile ?
I have the same problem, and I can for example change to my user profile by typingcd %userprofile%
in a command line.
Posted by: Pierre.Brico | Date: 2006-11-21 20:46 | IP: IP Logged
Hi Jan,
About the dictionary problem, I did some tests on my laptop (Windows XP SP2) and got the same result: PSPad doesn't find the dictionary in "PSPad editor\spell". In fact, monitoring PSPAD with filemon, the only place where it's looking for the dictionary is "c:\Program files\Common files\SynSpell". Below are my environment variables. You can see that the %USERPROFILE% variable doesn't point to Common Files. Might be PSPAD uses %CommonProgramFiles%.
Note this problem still exists in 2247.
Hope this helps,
Pierre
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\Pierre\Application Data
CLIENTNAME=Console
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=PANORAMIX
ComSpec=C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\Pierre
LOGONSERVER=\\PANORAMIX
NUMBER_OF_PROCESSORS=1
OS=Windows_NT
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Co
mmon Files\Adobe\AGL;C:\Program Files\Common Files\GTK\2.0\bin
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 6 Model 13 Stepping 8, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=0d08
PROMPT=$P$G
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\Pierre\LOCALS~1\Temp
TMP=C:\DOCUME~1\Pierre\LOCALS~1\Temp
USERDOMAIN=PANORAMIX
USERNAME=Pierre
USERPROFILE=C:\Documents and Settings\Pierre
windir=C:\WINDOWS
Posted by: raeubi | Date: 2006-11-21 21:13 | IP: IP Logged
pspad:If file is modified you should undo changes or save it. Into compiler you must send current file.
I have done the following:
- Open file with read only attributes in PSPad.
- Made no changes.
- Start the compiler.
