You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2246) English
Goto Page: 1 2 3 4 5 6 7 8 Next
Posted by: pspad | Date: 2006-11-20 17:18 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.3 (2244)
News
HTML, XHTML templates highlight support {code}
new scripting functions - blockBegin(x,y), blockEnd(x,y), - sets begin and end of the block, selectionMode(s: string) - sets selection mode - C:column, L:line, N:normal
color selection dialog in highlighter settings
ruller uses same colors as left gutter
Color select dialog
Corrections
FTP connections import from FileZilla
user highlighter for Abaqus - comment problem
statu bar icon redraw issue
FTP VMS - change directory
Posted by: MrSpock | Date: 2006-11-20 17:36 | IP: IP Logged
Thank you! I'm looking forward to a more beautiful status bar.
Posted by: JollyRoger | Date: 2006-11-20 18:15 | IP: IP Logged
pspad:new scripting functions - blockBegin(x,y), blockEnd(x,y), - sets begin and end of the block, selectionMode(s: string) - sets selection mode - C:column, L:line, N:normal
Jan, I needed to get the coordinates, not to set them.
There must have been a missunderstanding. I specifically requested more information, not more control. Maybe I'm missing something?
Posted by: JollyRoger | Date: 2006-11-20 18:29 | IP: IP Logged
When I try to do a spellcheck it says: "Dictionary English.2-1-0 not found". But the file is there, and it shows up in spell settings.
Posted by: pspad | Date: 2006-11-20 18:30 | IP: IP Logged
JollyRoger:When I try to do a spellcheck it says: "Dictionary English.2-1-0 not found". But the file is there, and it shows up in spell settings.
Ctrl+F7 (Spell settings) and choose dictionary
Posted by: JollyRoger | Date: 2006-11-20 18:33 | IP: IP Logged
I did that already. It doesn't help. Try it yourself.
Posted by: pspad | Date: 2006-11-20 18:41 | IP: IP Logged
I tried it before I answered you and it works without problems.
Enlish.2-1-0.dic really exists ?
Posted by: JollyRoger | Date: 2006-11-20 18:44 | IP: IP Logged
Yes. It's there:
D:\Program Files\PSPad\Spell>dir
Volume in drive D is sys
Volume Serial Number is E856-F0A7
Directory of D:\Program Files\PSPad\Spell
11/19/2006 11:40 PM <DIR> .
11/19/2006 11:40 PM <DIR> ..
07/23/2005 05:43 PM 4,067,321 English.2-1-0.dic
1 File(s) 4,067,321 bytes
2 Dir(s) 675,041,280 bytes free
Maybe I wasn't clear enough before: The English dictionary shows up in the spell settings. The program just acts like it doesn't.
Update: Tried it with build 2243. Spellcheck works again, so the bug was introduced somewhere between 2244 and 2246.
Edited 2 time(s). Last edit at 2006-11-20 19:02 by JollyRoger.
Posted by: Stealth | Date: 2006-11-20 19:01 | IP: IP Logged
Thank you for template support in html xtml mode!!
Posted by: pepperpod | Date: 2006-11-20 20:16 | IP: IP Logged
I get the same error message as JollyRoger - "Dictionary English.2-1-0 not found".
