You are here: PSPad forum > Bug report / Hlášení chyb > Re: Many crashes and corrupt files since 5.0.6 (character "ÿ" in files)
Goto Page: Previous1 2 3 4 5 6 7 8 9 10 Next
Posted by: macekt | Date: 2023-11-24 11:14 | IP: IP Logged
Tak špatná zpráva - chyba se projevila znovu i přes vypnutí zvýrazňování závorek,... Aktuální nastavení je toto:
Pokud máte nějaký další tip co vypnout/otestovat, rád to udělám.
Posted by: LouCypher | Date: 2023-11-25 16:09 | IP: IP Logged
Since I'm still very interested in the development regarding this nasty problem it would be very helpful if someone could give a short summary of the last czech posts. It would be very great if there are new insights
Posted by: pspad | Date: 2023-11-26 14:16 | IP: IP Logged
OK. Takže zvýraznění závorek nepomohlo.
Bylo by možné vypnout Code folding? Je to take v nastavení programu.
Podezření na vkládání ze schránky?
Posted by: vbr | Date: 2023-11-26 15:21 | IP: IP Logged
LouCypher:Since I'm still very interested in the development regarding this nasty problem it would be very helpful if someone could give a short summary of the last czech posts. It would be very great if there are new insights
it seems, unfortunately, that no new insights regarding this bug appeared in the latest observations.
Maybe there is a more detailed specification, e.g. in the post nr. 64, the faulty character tends to appear in place of the closing bracket } if it is originally preceded by a tab. It doesn't seem to appear on the position of } as the first, single character of the line.
The place of this kind of file corruption can generally be distant from the place being edited.
Furhtermore, no clear dependencies could be identified sofar (e.g. specific setting like syntax highlighter, bracket highligting, local or remote files etc.).
If you are interested in details in the previous posts in Czech, I think the automatic translation is quite well usable here, e.g.:
forum-pspad-com.translate.goog
(There are small mismatches like "code packaging" instead of "code folding", but in general, the translation seems to be ok.)
I am also hoping, this error could be identified and fixed.
Regards,
Posted by: pspad | Date: 2023-11-26 17:46 | IP: IP Logged
Few suspicious areas to be investigated.
Posted by: macekt | Date: 2023-11-27 07:13 | IP: IP Logged
Code folding vypnutý a jdu pracovat - uvidíme zda se problém objeví znovu.
Pokud to způsobuje kopírování ze schránky tak to bude z mé strany neodhalitelné - kopíruji totiž dost často. Ale je pravdou že v naprosté většině případů vykrádám sám sebe a beru kód z jiných otevřených PHP souborů nebo z toho samého na kterém zrovna pracuji. Naprosto výjimečně se stane že vložím kus textu z jihého programu než PSPad.
Další funkce kterou při editaci používám je doplňování slov (ctrl+j) - to není tak časté. Můžu zkusit chvíli pracovat také bez ní
Posted by: pspad | Date: 2023-11-27 07:29 | IP: IP Logged
Na vině by mohla být práce se schránkou, ne nutně kopírování z externího zdroje.
Posted by: macekt | Date: 2023-11-27 07:36 | IP: IP Logged
Ještě nápad zda problém nemůže souviset s funkcí, která v kódu označuje modifikované řádky. Nevybavuji si zda jsem toto zapínal sám nebo to vzniklo po nějaké aktualizaci - přijde mi že se toto objevilo realtivně nedávno. Myslím toto:
Posted by: pspad | Date: 2023-11-27 09:18 | IP: IP Logged
macekt:Ještě nápad zda problém nemůže souviset s funkcí, která v kódu označuje modifikované řádky. Nevybavuji si zda jsem toto zapínal sám nebo to vzniklo po nějaké aktualizaci - přijde mi že se toto objevilo realtivně nedávno. Myslím toto:
Ne. Ta nedela nic s obsahem radku, pouze kdyz dojde ke zmene radku, tak si zapamatuje stav.
Posted by: macekt | Date: 2023-11-27 10:30 | IP: IP Logged
Tak mám další chybu i s vypnutým code foldingem - asi jej můžeme vyloučit. Jen to bylo v této chvíli maličko jiná chyba - ten Y se dvěma tečkami se objevil tentokrát až na dalším řádku - TAB+} zůstal nezměněn a znak se objevil až na dalším řádku který byl původně prázdný.
A také v tomto případě určitě nešlo o kopírování ze schránky. Jen jsem otevřel soubor a v něm jsem změnil ručně 6 znaků a dalších 8 dopsal a uložil. Jediné kdy jsem použil schránku bylo na začátku kdy jsem použil ctrl+F a vložil název hledané funkce.
Nějaké další tipy na to co zkusit/vypnout?
