You are here: PSPad forum > Bug report / Hlášení chyb > Re: Many Crashes, many strange symbols ÿ
Goto Page: Previous1 2 3 4 5 6 7 8 9 10 Next
Posted by: LouCypher | Date: 2022-12-08 08:59 | IP: IP Logged
I know this. I just wanted to point to this option as a possible cause for the injected garbage data which you cannot reproduce.
Posted by: rseibel | Date: 2022-12-08 10:07 | IP: IP Logged
Problem occurs in other editor tabs without doing anything.
Switched just in the moment to a second tab to change something,
went back to first tab an my text has changed (.... = 1 TAB Hex 09):
CASE KEY9
....// Langtexte
....IF PROC POS_Current ()
........IF PROC s_langtext.textObjAuswahl (O_PREISLISTE, vk_preislisten.pl_nr, "", PROC s_langtext.getEditModus("")) END
ÿ EN
........CONTINUE
....CASE KEY10
'END' was replaced with HEX-Codes: FF 00 45 4E
Occurs for me always at line ends, then following CR LF = 10 0A ...
Perhaps important: Tabs (HEX 09) in front of this erroneous replacements are always gone/deleted.
Good luck
Edited 4 time(s). Last edit at 2022-12-08 10:11 by rseibel.
Posted by: rseibel | Date: 2023-01-19 10:27 | IP: IP Logged
I try every new beta (always 32 bit), but this errors never disappear.
For me this is the most important point to use pspad further on.
Some time ago i donated for this editor, i love it,
but working with it gets more and more frustrating.
I hope that you are able to have a special look into this errors.
Regards
Roger
Posted by: rseibel | Date: 2023-04-04 13:54 | IP: IP Logged
Nothing changes here, every stable and beta version (32b) has this problems,
is there any chance that this error gets fiexed?
For me this is a logical programm error, no memory error,
memory errors mostly would be random.
CASE KEY9
....// Langtexte
ÿ EN
........CONTINUE
....CASE KEY10
Posted by: pspad | Date: 2023-04-04 14:31 | IP: IP Logged
Do you use current developer build?
Do you have set any background activity like autosave?
Can you send me yout PSPad.ini?
Posted by: LouCypher | Date: 2023-04-05 04:39 | IP: IP Logged
I mentioned this before and it might be stupid. But the garbage data looks always very similar and reminds me vaguely to an accidentally injected BOM. Or maybe a misplaced character coding?
Posted by: pspad | Date: 2023-04-05 05:06 | IP: IP Logged
Or maybe problem in the highlighter implementation or...
It's really hard to answer.
But he mentioned that it happens to files on the background. This is strange.
Posted by: LouCypher | Date: 2023-04-05 05:15 | IP: IP Logged
Well, it happens without editing something but it doesn't really happen without doing anything. It does happen when you switch from one tab to another. So at least the window content is refreshed to redisplay the file from the selected tab.
Posted by: pspad | Date: 2023-04-05 08:10 | IP: IP Logged
Can you please confirm it happens in current developer version too?
I made some changes in highlighter background what can have influence of it.
Posted by: rseibel | Date: 2023-04-05 09:00 | IP: IP Logged
As i said before: in every version since approx. three years,
stable and (latest) beta, only 32 bit.
I dont use 64 bit because of other errors ...
Autosave was enabled, i will try with disabled now.
After new betas, i immediately check for changes ...
Regards, Roger
Edited 2 time(s). Last edit at 2023-04-05 09:03 by rseibel.
