You are here: PSPad forum > Bug report / Hlášení chyb > Unwanted and sudden converting to strange characters
Posted by: khagaroth | Date: 2020-08-01 08:20 | IP: IP Logged
Diff tool is unrelated. No need for any external tools or plugins, it's PsPad itself that does the damage. I once got this on a plain TXT file without any syntax highlighting and without using any functions like search/replace, just plain manual text editing and then saving. Though it was a while ago, cca 2 years, no such issues with recent versions on such simple files, but it still occasionally happens on more complex files/with more complex editing.
Posted by: Andreas | Date: 2020-08-15 10:59 | IP: IP Logged
PSPad (32b) 504 (515)
I don't know when this file was destroyed.
Application error appeared after trying to close the file tab.
Error log:
Exception description:
Access violation at address 0040985E in module 'PSPad.exe'. Read of address 000000FF.
Exception class: EAccessViolation Exception address: 0040985E ---------------------------------------------------------------------------------------------------- Stack list, generated 15.08.2020 12:59:21 [0040985E] System.TObject.Free + $6 [0063002E] Vcl.Themes.TSysStyleHook.DrawParentBackground + $52 [0040A1BC] System.TMonitor.CheckOwningThread + $4 [0040A4DE] System.TMonitor.Exit + $6 [0040A53A] System.TMonitor.Exit + $1A [004D9DA2] System.Classes.RemoveFixups + $7E [00409FF5] System.@BeforeDestruction + $9 [0054DFBE] Vcl.Graphics.TIconImage.Destroy + $E [00409860] System.TObject.Free + $8 [0054B0F4] Vcl.Graphics.TSharedImage.Release + $18 [0054E356] Vcl.Graphics.TIcon.Destroy + $E [00409860] System.TObject.Free + $8 [006736FD] Vcl.Forms.TCustomForm.Destroy + $B9 [00409860] System.TObject.Free + $8 [00679724] Vcl.Forms.TCustomForm.CMRelease + $0 [006AC9DE] Vcl.Controls.TControl.WndProc + $2BE [006AD205] Vcl.Controls.TControl.WMMButtonDown + $1D [006AC9DE] Vcl.Controls.TControl.WndProc + $2BE [006B18C6] Vcl.Controls.TWinControl.WndProc + $686 [004EA7E8] System.Classes.StdWndProc + $14 [006B18C6] Vcl.Controls.TWinControl.WndProc + $686 [0040A828] System.TMonitor.TryEnter + $28 [0040A350] System.TMonitor.Enter + $10 [0040A1BC] System.TMonitor.CheckOwningThread + $4 [0040A53A] System.TMonitor.Exit + $1A [0040A828] System.TMonitor.TryEnter + $28 [0040A350] System.TMonitor.Enter + $10 [006B1089] Vcl.Controls.TWinControl.IsControlMouseMsg + $65 [006B18C6] Vcl.Controls.TWinControl.WndProc + $686 [00674E09] Vcl.Forms.TCustomForm.WndProc + $691 [006B0E48] Vcl.Controls.TWinControl.MainWndProc + $2C [004EA7E8] System.Classes.StdWndProc + $14 [0067EB53] Vcl.Forms.TApplication.ProcessMessage + $F3 [0067EB96] Vcl.Forms.TApplication.HandleMessage + $A [0067EEC9] Vcl.Forms.TApplication.Run + $C9 [00ABC205] PSPad.PSPad (Line 119, "" + 55) + $7 ---------------------------------------------------------------------------------------------------- Program : C:\Portable\PortableApps\_pspad\PSPad.exe 5.0.4 (515) System : Windows 10 Home Edition x64, Version: 10.0, Build: 47BB, Processor: Intel, Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz, 2590 MHz MMX Display : 1920x1200 pixels, 32 bpp PPI: 96 Skin : Windows ---------------------------------------------------------------------------------------------------- Active Controls Hierarchy: TPSSynEdit "FEditor1" TfChildEdit "fEdit_E66840711" ----------------------------------------------------------------------------------------------------
Edited 1 time(s). Last edit at 2020-08-15 11:04 by Andreas.
Posted by: Andreas | Date: 2020-08-15 11:14 | IP: IP Logged
Was able to click OK. Closed PSPad, started PSPad, opened the file again. Luckily the file was not saved.
Posted by: syntech | Date: 2020-08-20 07:51 | IP: IP Logged
@jan:
Any progress here? Is this on your top priority list? Just asking...
Posted by: pspad | Date: 2020-08-20 14:42 | IP: IP Logged
It's on my priority list, but I don't have point to start.
My suspicioun is on the PHP highlighter.
I changed memory manager in current 5.0.4 build, I am trying to find memory leaks.
But if the problem occurs in page drawing + folowed actions like highlight all selections e.t.c. it's very hard to find it.
Posted by: syntech | Date: 2020-08-21 05:52 | IP: IP Logged
@jan:
Do you mean the highlighter for PHP code? I'm only using CPP highlighter because I'm C/C++ software developer. My strong feeling is, it has something to do with
'else' and curly brackets {}, because the garbage is either (in my case) after a closing } or where an 'else' is.
Posted by: pspad | Date: 2020-08-21 06:02 | IP: IP Logged
Can you try to switch off bracket highlight in the progeam settings / editor for a while?
Posted by: Veronika | Date: 2020-09-03 09:35 | IP: IP Logged
Hi, I also have this problem with the occasional ÿ appearing along with some more garbage in the same line, mostly in PHP code, but at one time it also happened with the .ppr project file itself.
The project file was not "open" as a tab, it just happened when I clicked save project and PSPad crashed with an error. Unfortunately I don't have the error report. Normally I never look inside the .ppr files, but PSPad could not open the project anymore and I found the ÿ-problem inside when I looked.
I have turned off bracket highlighting for now to see if it helps, but the issue is not that frequent so it is hard to catch.
Posted by: Ravelli | Date: 2020-10-13 03:13 | IP: IP Logged
I had this issue just two days back in PSPad 5.0.4(527) with a PHP file of ~780 lines, "Unicode UTF-8 no BOM (65001)" code page, and HTML multihighlighter. The garbage occurred somewhere in the middle of the file, an 'echo' command got replaced, maybe some characters more. But I was working at the top of the file, and saving it all few seconds via CTRL+S.
Because I know about this bug since a while, I did not think much about it, just replaced the broken section from a backup. So I don't know which steps I did exactly before the issue came up.
Luckily it happens less often than in the past.
Friendly greetings,
Ravelli
Posted by: falk73 | Date: 2021-05-05 07:59 | IP: IP Logged
I have with the version 5.0.6 (589) with the Tcl Highlighter also still the problem
