You are here: PSPad forum > English discussion forum > How to convert HTML to TXT? in PSPad
Posted by: maki | Date: 2019-12-28 19:43 | IP: IP Logged
Coding 1251 (Russian)
Ďîđňŕë ===> Портал
Posted by: pspad | Date: 2019-12-28 19:57 | IP: IP Logged
Menu HTML / REMOVE TAGS
or
Html preview / copy and paste into txt
Posted by: maki | Date: 2019-12-28 20:14 | IP: IP Logged
Html preview = Very, very Slow Open webpage
Not work! The text is confused and what is it? Even the encoding cannot be changed!
Quote:îńňŕâčň âŕń îäíó č ńäĺëŕĺň
Edited 1 time(s). Last edit at 2019-12-28 20:15 by maki.
Posted by: pspad | Date: 2019-12-28 20:30 | IP: IP Logged
Web preview is as fast as your browser.
Provide me some text sample - send it to support mail
Posted by: pspad | Date: 2019-12-28 20:41 | IP: IP Logged
maki:Html preview = Very, very Slow Open webpage
Not work! The text is confused and what is it? Even the encoding cannot be changed!Quote:îńňŕâčň âŕń îäíó č ńäĺëŕĺň
If you want to solve any problem, you need to provide information leading to solution.
For me it works. I just tested it.
If you have some specific page, first your HTML source be readable - open in correct code page in PSPad. Remove tags function doesn't noything else than take existing text and removes HTMl tags. It does no code page conversion.
It means your HTML source wasn't properly open in editor.
Posted by: maki | Date: 2019-12-28 23:33 | IP: IP Logged
It doesn't matter what encoding you change, it shows me the same encoding all the time - incorrect!
I only know that it is a Russian font (Cyrillic).
I tested several tools to change HTML to TEXT and always damaged text.
There is no tool that can convert to Unicode.
Opening a file in Chrome ALWAYS shows correctly. And only in the browser correctly shows the encoding.
PSPad - WRONG!
i.postimg.cc
Other Editor - 100% Work!
i.postimg.cc
Notepad++ - 100% Work!!!
i.postimg.cc
Edited 4 time(s). Last edit at 2019-12-28 23:39 by maki.
Posted by: pspad | Date: 2019-12-29 05:47 | IP: IP Logged
I requested you to send me sample. You didn't send it. Without samoke I can't help you.
Posted by: pspad | Date: 2019-12-29 07:02 | IP: IP Logged
I opened (File / Open special / Open from intenet) e.g.
www.nic.ru
Save is in ANSI 1251 and close PSpad.
I opened it in PSpad again and let PSpad remove tags. All was OK. I see cyrilic text without tags.
Problem is on your side.
Posted by: maki | Date: 2019-12-29 08:25 | IP: IP Logged
Stop saying that the problem is with me, the problem is with the PSPad.
Quote:<title>Íĺ ďđîůŕéňĺ ďđĺäŕňĺëüńňâî</title>
Not work change:
Edited 2 time(s). Last edit at 2019-12-29 08:28 by maki.
Posted by: maki | Date: 2019-12-29 08:32 | IP: IP Logged
www.nic.ru <=== This is UTF-8 NO BOM Not 1251 !!!)
Work PSPad, but not work other website cp1251
Edited 4 time(s). Last edit at 2019-12-29 08:40 by maki.
