You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.1 (815) English
Goto Page: Previous1 2 3 4
#31 Re: PSPad unicode 5.5.1 (815) English
Posted by: tmpad | Date: 2024-10-24 12:49 | IP: IP Logged
The last update of PSPad is appx. 8 months old. Yesterday I came across the "Chinese characters issue" again.
When can we expect an update and especially an improvement of the "Chinese characters issue"?
#32 Re: PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-10-24 12:53 | IP: IP Logged
I am slowly work on editor engine replacement.
I hope new engine will be faster and better.
#33 Re: PSPad unicode 5.5.1 (815) English
Posted by: Freeman | Date: 2024-10-24 14:23 | IP: IP Logged
Wow, great news!
#34 Re: PSPad unicode 5.5.1 (815) English
Posted by: AD7 | Date: 2024-11-06 10:30 | IP: IP Logged
Any screenshots from development? smiling smiley
#35 Re: PSPad unicode 5.5.1 (815) English
Posted by: Freeman | Date: 2024-11-19 18:11 | IP: IP Logged
One more question/request from me.
When first time opened file is 7-bit, and actual code page cannot be determined, PSPad sets it to ANSI encoding, regardless default code page setting in Options window. This behavior exists from the time I ever started to use PSPad. Is this a bug or a feature?
Now I often edit markdown files with metadata. Metadata keywords are English, so if I type or paste Russian text then, I suddenly get errors from markdown compiler because PSPad saved my page in 1251 code page while that compiler supports only UTF-8. Default code page in Options is to UTF-8 no BOM, but works only for new files created in PSPad, and keeps only when non-Latin characters entered.
#36 Re: PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-11-19 18:36 | IP: IP Logged
When there is no possibility to detect UTF-8, e.g. file doesn't contains cyrilic encoded into UTF-8, there is no chance to recognize if file is in UTF-8
Click on the code page on the status bar (or select it in the encoding menu), switch to UTF-8 and reload (Ctrl+R).
Switch on remember file state in program settings / Files - part of information is file code page.
Put on the begin of file any comment with anything encoded in UTF-8 (e.g. few cyrilic letters) - it will ensure correct detection
#37 Re: PSPad unicode 5.5.1 (815) English
Posted by: Freeman | Date: 2024-11-20 11:23 | IP: IP Logged
I agree, but my thought is about different thing.
I don't want to remember to do that every time I open new markdown files. Why just don't set default code page instead of hard-coded ANSI one, on PSPad side? I think, there is an exact line of legacy PSPad code that does that assignment.
This is just workaround, not bugfix. I just want to make PSPad follow its own setting in one more case – when 7-bit ASCII file loaded (in addition to new file creation). Please use code page value from the Options tab you mentioned above.
#38 Re: PSPad unicode 5.5.1 (815) English
Posted by: Freeman | Date: 2024-11-30 19:24 | IP: IP Logged
What algorithm is used for file autosave period calculation? Does PSPad start from zero when previous idle time was longer than autosave time set in Options? I think no, because sometimes PSPad overwrites files very quickly.
#39 Re: PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-11-30 20:46 | IP: IP Logged
Ot should be reset from the last save, cause there is a timer what execute event when period is over.
If PSPad is busy, it can be little longer time. But it shouldn't be shorter than the period you set up.
