You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2395) English
Goto Page: Previous1 2 3 4 5 6 7
Posted by: papi | Date: 2011-02-03 15:04 | IP: IP Logged
tscaffidi:if you open a text file which has lines longer than 1024 characters, and move the horizontal scroll bar at the end of all his race, the text is not positioned at the end of the line, but the 1024-th character
bye
Tonino
I can confirm it, expanding with the thing, that even longer this line is, PSPad needs even more and more time to open. And then, it is even more complicated to edit this file... After any action i do(pressing key, clicking in line, scrolling), need to wait 5-10 seconds (or even more) until this is done (search, replace even worst).
You could see that with file size above 1Mb (above 2Mb it is surly difficult to work with). If the content is not in 1 line, PSPad could work with it quite good.
I tried several PSPad settings, but this is always the same problem...
Would it be possible to fix?
Thanks!
P.
Posted by: Marten | Date: 2011-02-06 12:32 | IP: IP Logged
I'm using a GNU C++ compiler in combination with pspad.
After an error report, pspad opens the file with the error once again, even if the file is already open.
Posted by: pspad | Date: 2011-02-06 13:48 | IP: IP Logged
Marten:I'm using a GNU C++ compiler in combination with pspad.
It's already reported.
Can you send me to support mail content of your LOG? I need line with file name
Posted by: Marten | Date: 2011-02-07 14:48 | IP: IP Logged
It's not exactly clear to me what you mean. But next you find the error log:
mktrun from mkt V0.08
mkt V1.00 (2011-01-31)
gather configuration
create temporary files
building library for lpc2148
compile c:\temp\_mkt_temp\_mkt_cpp_pRTOS.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_Button.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_Beeper.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_BeeperHandler.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_Display.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_I2CBus.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_TemperatureSensor.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_EnergySensor.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_EventHandler.cpp
compile c:\temp\_mkt_temp\_mkt_cpp_OperationController.cpp
In file included from OperationController.cpp:3:
OperationController.h:14: error: 'clas' does not name a type
OperationController.cpp:9: error: 'OperationController' has not been declared
OperationController.cpp:15: error: ISO C++ forbids declaration of 'OperationController' with no type
OperationController.cpp: In function 'int OperationController(int, Button&, Display&, BeeperHandler&, MeasurementHandler&)':
OperationController.cpp:15: error: only constructors take base initializers
OperationController.cpp:21: error: invalid use of 'this' in non-member function
OperationController.cpp:22: error: invalid use of 'this' in non-member function
OperationController.cpp:23: warning: no return statement in function returning non-void
OperationController.cpp: At global scope:
OperationController.cpp:27: error: 'OperationController' is not a class or namespace
OperationController.cpp:27: error: '::main' must return 'int'
OperationController.cpp: In function 'int main()':
OperationController.cpp:29: error: 'theButton' was not declared in this scope
OperationController.cpp:29: error: invalid use of 'this' in non-member function
OperationController.cpp:35: error: 'standby' was not declared in this scope
OperationController.cpp:36: error: 'theLcd' was not declared in this scope
OperationController.cpp:37: error: 'btnFlag' was not declared in this scope
OperationController.cpp:37: error: 'wait' was not declared in this scope
OperationController.cpp:45: error: 'stbTimer' was not declared in this scope
OperationController.cpp:46: error: 'theMeasurementHnd' was not declared in this scope
OperationController.cpp:51: error: 'theBeeperHnd' was not declared in this scope
OperationController.cpp:65: error: 'OperationController' is not a class or namespace
OperationController.cpp: In function 'void suspend()':
OperationController.cpp:70: error: 'stbTimer' was not declared in this scope
OperationController.cpp:71: error: cannot call member function 'virtual void RTOS::task::suspend()' without object
Error: compilation failed
Process completed, Exit Code 0.
Execution time: 00:06.144
The file containing the error is reopened if I start the compilation with another file as the file currently selected in the editor.
Version 2405 also contains this glitch.
