You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2395) English
Posted by: se7h | Date: 2010-08-04 21:44 | IP: IP Logged
Hanno:- create a new file with a very long line (longer than the pspad window is able to display)
- press CTRL+W
-> you can see the hole line- press CTRL+W again
=> Now there is NO scroll bar available!
confirm this bug
WinXP Pro SP3
Posted by: Ilya | Date: 2010-08-05 04:43 | IP: IP Logged
se7h:Hanno:- create a new file with a very long line (longer than the pspad window is able to display)
- press CTRL+W
=> Now there is NO scroll bar available!confirm this bug
WinXP Pro SP3
The Tcl file with 13350 characters in a line looks OK - the horizontal scrollbar appears and available without wrapping, and the vertical bar - with the wrapping.
WinXP pro sp3
Tested on PSPad 2392 and 2395
Posted by: Hanno | Date: 2010-08-05 06:41 | IP: IP Logged
I use XP Pro. (SP3, english).
PSPad: 2395
CTLR+W & CTRL+W
-> Scrollbar disappears
CTLR+W & CTRL+W again
=> Scrollbar appears
... and so on
Edited 1 time(s). Last edit at 2010-08-05 06:42 by Hanno.
Posted by: jy02094764 | Date: 2010-08-20 14:04 | IP: IP Logged
Luckly, I found this wonderful code editer, and I love that picture, ha ...
Posted by: c3k | Date: 2010-08-23 15:54 | IP: IP Logged
sandrosilveira:See video in link: www.youtube.com if the resolution are bad say me how to send original video with 2.6MB to you.
I confirm that check changes problem is still present (started in january 2010: forum.pspad.com and reported on almost every update)
After losing another set of code lines, sadly back to 2357...i think definitively stop here until i have time to switch to a different editor, sorry Jan i like your work but too much time lost for this issue
Edited 4 time(s). Last edit at 2010-08-23 16:03 by c3k.
Posted by: pspad | Date: 2010-08-23 17:15 | IP: IP Logged
I believe you, but I am not able to simulate it.
I don't know nobody with same behaviour to be able detect problem.
I don't know it there is nonstandard windows appbar settings or something else
Posted by: Neil | Date: 2010-08-23 23:17 | IP: IP Logged
sandrosilveira:In 2395, PSPad don´t prompt that the files had been changed for me too, it is very important because our programmers edit files in a same directory.
Yes - happening to me too.
Neil
Edited 2 time(s). Last edit at 2010-08-23 23:19 by Neil.
Posted by: khagaroth | Date: 2010-08-25 10:04 | IP: IP Logged
Actually I get the opposite, it tries to convince me a file changed even though it actually didn't. This happens any time I open (RO) an edited file in an external viewer (for example html in Firefox). Could be a W7 quirk, but annoying as hell.
Posted by: Neil | Date: 2010-08-26 22:44 | IP: IP Logged
khagaroth:Actually I get the opposite, it tries to convince me a file changed even though it actually didn't. This happens any time I open (RO) an edited file in an external viewer (for example html in Firefox). Could be a W7 quirk, but annoying as hell.
Yes I get this one too
Th application i am editing files for is an interpreter, i.e. it reads files in real-time.
The application locks the file while it is being read.
PSPad then reports that the file has been changed !!
Neil
Neil
Posted by: wimb | Date: 2010-09-08 22:48 | IP: IP Logged
The cab file to download is send with content-type text/plain. That causes firefox to open it and display the contents in the browser when I click the link.
Of course it is possible to right click and select save.., but I hope that it is possible that the file is send with the correct content-type so I can left-click on it to open it in another application.
(i.e. see en.wikipedia.org)
Thanks, W
Edited 1 time(s). Last edit at 2010-09-08 22:48 by wimb.
