You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2262) English
Goto Page: 1 2 3 4 5 6 7 8 Next
Posted by: pspad | Date: 2007-03-18 16:29 | IP: IP Logged
Download links:
pspad.cincura.net (1.7 MB)
pspad.siliconhill.cz (1.7 MB)
Changes to 4.5.3 (2261)
News
Increased speed of language listing in Program settings
Each window has own statusbar - it removed statusbar redraw problems
Incremental search isn't modal, click outside closes it
Added %AllUsersProfile% variable for compillers and external applications
Script function getVarValue() returns any system variable
Modified script function inputText(label, default, cancel: string): string. If filled in optional "cancel value", dialog returns it if Cancel buutton was pressed
Corrections
Corrected problem running last build under Windows 98
File tabs visibility after PSPad start
Problem with KeyMap / Editor section
Redraw window without highlighting after PSPad activate
Function Search / Copy non matched removes blank lines
Posted by: MrSpock | Date: 2007-03-18 19:03 | IP: IP Logged
Thank you for the new build. Love to hear that you finally found the cause of this annoying little status bar redraw problem.
Posted by: Beard | Date: 2007-03-19 08:18 | IP: IP Logged
I just tested the new version with win98.
I have still the same problem:
With TotalCommander and PSPad as editor.
First press of TC F4 file loaded ok in PSPad.
Second file with TC F4 it apears in PSPad, but before
PSPad.exe is loaded in hex-edit mode.
So there are 3 files opened.
Still have to use 'notpad.exe' entry in TC to avoid
this.
Best regards,
Beard
Posted by: pspad | Date: 2007-03-19 08:59 | IP: IP Logged
Open Total commander config, go to Edit/View tab and search PSPad.EXE in dialog.
Confirm.
Still problem exits?
Posted by: Brico P. | Date: 2007-03-19 10:18 | IP: IP Logged
Hi Jan.
I think there still is a small bug in the "word wrap lines" feature. When you turn it on and when you have lines with only one character more than the limit, this character is repeated twice...
Pierre
PS: Thanks for this new release !!
Posted by: Ptit Lutin | Date: 2007-03-19 13:38 | IP: IP Logged
Hi
There is still a bug with print preview
See : Print preview does not display font size 8 correctly
Posted by: pspad | Date: 2007-03-19 15:03 | IP: IP Logged
Brico P.:Hi Jan.I think there still is a small bug in the "word wrap lines" feature. When you turn it on and when you have lines with only one character more than the limit, this character is repeated twice...
Go to program settings / Editor and diable
[]Wrap soft with right edge
Posted by: Markus Kiendl | Date: 2007-03-19 16:08 | IP: IP Logged
Ptit Lutin:HiThere is still a bug with print preview
Hi!
I already described this problem several times and already thought it didn't matter anyone but me. The buggy display in the print preview apparently depends on the font size in conjunction with the scaling factor used in the print preview. To prove this, select "whole page" or "page width" as scaling factor in the print preview using the toolbar button with the magnifier glass on it, and then resize the print preview window. You will see the print preview toggling between correct and buggy display. I guess it's kind of a rounding bug when creating the font for drawing the print preview window. I'm waiting at least since half a year for a solution of this problem.
Markus
Posted by: jgodfrey | Date: 2007-03-19 16:35 | IP: IP Logged
Hi Jan,
Thanks for the build. I know you're busy, but since I can't get a response or a fix, I'm not sure whether I should continue to ask or not...
If it's on a list, just say so and I'll quit pestering you about it... ;)
Can the "Find" function (Ctrl-F) be made to wrap around the end of a file as it used to (for instance, build 2237 works correctly). Checking "Settings | Program Settings | Confirmation | Ask if OK to wrap search when text found" works as expected. That is, PSPad will ask to wrap the search, and does so if asked. If that option is *unchecked*, PSPad will not ask, but also *will not* wrap the search around the end of the file.
Older builds used to (correctly) just continue the search with no prompt when the above option was turned off. Can this be easily fixed? I just want to wrap the search without having to respond to the prompt.
Thanks for all your efforts.
Jeff Godfrey
Posted by: shutnik | Date: 2007-03-19 18:40 | IP: IP Logged
when will have new version? I very much look forward to it, because the program does not officially updated for quite some time ...
