You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2262) English
Posted by: nyjl | Date: 2007-03-26 15:08 | IP: IP Logged
Thanks for a great editor
I have seen a problem for the last few betas but have only recently figured out what's wrong
I like to use 'Lucida Sans Typewriter' as the font in my editors but there is a problem if a file with real tab characters is loaded. If a word is double-clicked or a selection is dragged over the text then characters other than the ones selected are highlighted.
Other fonts do not seem to show this problem
Thanks
Posted by: Progress coder | Date: 2007-03-26 19:41 | IP: IP Logged
Lolo:Hello Jan,I have found a strange bug with "Save As..." dialog box.
Hello Jan,
I've seen this problem too, and also when I try to save a file without extention, it will not succeed (I select 'Save as type' : 'All files (*.*)').
PSPad will take the extention of Files and Dirs -> New Default.
And when I deselect 'Always this type' a file is saved with the extention of the linked Syntax Highlighting. For example a js file can not be saved without extention js.
Posted by: Markus Kiendl | Date: 2007-03-26 20:22 | IP: IP Logged
Lolo:I have found a strange bug with "Save As..." dialog box.For information, I am on Windows 2000 sp4.
I confirm this bug.
Markus
(running Windows XP SP2)
Posted by: DaveTorr | Date: 2007-03-28 09:38 | IP: IP Logged
At last I can generate a log - did a "Close All" with about 4-5 tabs open and it crashed with a log - has previously crashed (without a log!) if I just close the app when several tabs open.
Posted by: wayshore | Date: 2007-03-28 10:14 | IP: IP Logged
Quote:corrections: File tabs visibility after PSPad start
Hello Jan, thanks for all you're good work.
I have to say, that, running XP SP2, the tabs-
problem still consists.
After starting editor, they aren't visible and
appear only when loading another project or
making changes in the configuration.
Thanks.
Posted by: Fraerok | Date: 2007-03-28 19:54 | IP: IP Logged
When the new final version will be realesd?)
Posted by: CMan | Date: 2007-03-29 10:16 | IP: IP Logged
pspad:CMan:There is a problem with a HTML page preview. When I press "Show tables conture" I get this: http://img340.imageshack.us/img340/167/pspadzz7.png. I use Windows Vista.And?
Ok. I will show you how it looks in full screen: http://img95.imageshack.us/img95/976/pspadwz3.png
Posted by: owilsky | Date: 2007-03-29 14:27 | IP: IP Logged
Bug with not working getVarValue is still present in 2262:
I created a var called %test% with the content "test".
I tried this script (JScript):
var text = getVarValue("%test%");
echo(odinEXE);
Did return an empty string, not test.
My Variable.INI show this (shortened):
[User variables]
%test%=test
Oliver
Oliver Kötter
Posted by: pspad | Date: 2007-03-29 14:34 | IP: IP Logged
echo(odinEXE);
Sorry, but odinExe should contains content of the %test% variable?
Did you try it with echo(text); ?
Posted by: owilsky | Date: 2007-03-29 14:46 | IP: IP Logged
upps.... sorry. Paste and copy error.
Yes, I tried it with test.
This is the correct script and it does NOT work.
var test = getVarValue("%test%");
echo(test);
Oliver
Oliver Kötter
Edited 1 time(s). Last edit at 2007-03-29 14:47 by owilsky.
