You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2231) English
#21 Re: PSPad unicode 4.5.2 (2231) English
Posted by: steph | Date: 2006-08-04 17:41 | IP: IP Logged
It seems that log windows display still have troubles :
- first log messages are displayed correctly,
- then all messages are written in the first column (letters upon each others)
this appeared in build 2227
see forum.pspad.com
and forum.pspad.com
and forum.pspad.com
#22 Re: PSPad unicode 4.5.2 (2231) English
Posted by: Mark Baines | Date: 2006-08-04 19:53 | IP: IP Logged
MrSpock:
Mark, you have to select the text you want to make a comment before hitting <Ctrl>+<Space>. Then it should work.
Stupid me, yes, of course selecting does help smiling smiley and so does using the keyboard.
There is a problem using mouse middle click to bring up the <Ctrl>+<Space> dialog. It appears to unselect the text and places /**/ at the beginning of the line.
#23 Re: PSPad unicode 4.5.2 (2231) English
Posted by: Mark Baines | Date: 2006-08-04 19:55 | IP: IP Logged
Selecting text with mouse left-click in left gutter places the text cursor at the beginning of the next line.
Has it always done this? I don't remember it doing so.
Thanks again.
#24 Re: PSPad unicode 4.5.2 (2231) English
Posted by: pspad | Date: 2006-08-05 09:38 | IP: IP Logged
Mark Baines:
Thanks again.
Program settings / Direct edit button
Change:
GutterClickInclLF=0
#25 Re: PSPad unicode 4.5.2 (2231) English
Posted by: Mark Baines | Date: 2006-08-05 12:36 | IP: IP Logged
Mark Baines:
Thanks again.
Change:
GutterClickInclLF=0
Thank you. Putting these settings into the proper config dialog is going to save you a lot of time here in this forum smiling smiley
#26 Re: PSPad unicode 4.5.2 (2231) English
Posted by: Mark Baines | Date: 2006-08-05 15:31 | IP: IP Logged
This bug has come back in word wrap mode.
Left click in left gutter to select a long wrapped line and it only selects the first line of the block. If I make GutterClickInclLF=1 it does select the whole wrapped line. Make GutterClickInclLF=0 and it only selects first line.
thanks
#27 Re: PSPad unicode 4.5.2 (2231) English
Posted by: imiglikos2 | Date: 2006-08-07 05:48 | IP: IP Logged
Hi Jan,
is it possible to develop the FTP-dialog resizable (to display the list of servers without scrollbar)?
Thanks in advance, Markus
#28 Re: PSPad unicode 4.5.2 (2231) English
Posted by: pspad | Date: 2006-08-07 06:41 | IP: IP Logged
imiglikos2:
Hi Jan,
No problem
#29 Re: PSPad unicode 4.5.2 (2231) English
Posted by: stefan gabos | Date: 2006-08-08 07:15 | IP: IP Logged
the talk about the ftp window reminds me: when i save a file through ftp, pspad will go to the folder where the file was opened from. is it possible, when saving a file on the local disk, the file browser to go to the folder where the file was opened from?
thanks!
#30 Re: PSPad unicode 4.5.2 (2231) English
Posted by: pspad | Date: 2006-08-08 19:01 | IP: IP Logged
stefan gabos:
thanks!
Program settings / Files / (o)Same as active document
or use Synchronize button on the File Explorer
