You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2231) English
#31 Re: PSPad unicode 4.5.2 (2231) English
Posted by: imiglikos2 | Date: 2006-08-10 08:50 | IP: IP Logged
Hi Jan,
one more suggestion to improve productivity: What about a shortcut (like STRG-Y in microsoft excel) to repeat the last user action? Last typed char, last command or whatever... Just execute once again... Or already exist something like that?
Best regards, Markus
#32 Re: PSPad unicode 4.5.2 (2231) English
Posted by: pspad | Date: 2006-08-10 09:40 | IP: IP Logged
imiglikos2:
Hi Jan,
Menu tools / Repeat last command (Alt+Q)
#33 Re: PSPad unicode 4.5.2 (2231) English
Posted by: rv66 | Date: 2006-08-10 09:57 | IP: IP Logged
Code Explorer window / File SQL (Interbase)
The names procedure with $, This is don't full names.
Example :
name procedure : FS$_TEST
In Code Explorer windows = FS
#34 Re: PSPad unicode 4.5.2 (2231) English
Posted by: ShiLong | Date: 2006-08-10 10:49 | IP: IP Logged
Try this for unexpected error:
1. open pspad
2. open html document & highlighter
3. hold down F10 button
4. enjoy! ;)
#35 Re: PSPad unicode 4.5.2 (2231) English
Posted by: pspad | Date: 2006-08-10 10:49 | IP: IP Logged
Sorry, there was a problem.
#36 Re: PSPad unicode 4.5.2 (2231) English
Posted by: whacker | Date: 2006-08-11 15:05 | IP: IP Logged
ctrl S does not work.
#37 Re: PSPad unicode 4.5.2 (2231) English
Posted by: pspad | Date: 2006-08-11 15:10 | IP: IP Logged
whacker:
I don't understand. Whwen it doesn't work ?
#38 Re: PSPad unicode 4.5.2 (2231) English
Posted by: Jody | Date: 2006-08-11 21:05 | IP: IP Logged
Ctrl-s works for me.
XP Home SP2
#39 Re: PSPad unicode 4.5.2 (2231) English
Posted by: gf_gollum | Date: 2006-08-14 08:02 | IP: IP Logged
Small point. The current installer for the none beta product installed to \program files\PSPad editor\ by default - yet the CAB files have a directory tree based round PSPAD - Can the none beta installer go back to using PSPad as a folder name - then uprgades would be simpler.
Thx
Graham
#40 Toolbars gone
Posted by: normally | Date: 2006-08-16 15:34 | IP: IP Logged
Likely something screwy on my end, but I can't figure it out. Since updating to this newest version, all of my toolbars are gone. They're all checked off in the View menu, but they don't show up. I've tried going back to the stable version and they still won't show up. I've tried installing to a totally new directory and they still don't show up. I've gone through the settings and can't find anything that would (obviously) turn them off.
So... where have I screwed up? smiling smiley
Thanks!
