You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2231) English
Posted by: pinus_ | Date: 2006-08-03 10:53 | IP: IP Logged
The TeX highlighting does not work properly. On the first occurrence of $$, it switches to green color, but it never switches back - i.e. it does not recognize terminal $$, nor \end{eqnarray} etc.
Posted by: Stefan | Date: 2006-08-03 11:21 | IP: IP Logged
Lolo:It is what I am talking about but my english isn't very good.
I probably badly expressed myself.
No problem, you are welcome too
And your english is good enought.
Quote:Otherwise, like Stefan, I would like to know what is exactly "Cycle marks".
I would like to translate it but I don't really know what is it for?
I have think about "Cycle".
I have tested it in my launch break:
"Cycle marks" is no Confirmation
but an option.
If "Cycle marks" is checked
i can jump from the last mark (red bookmark/yellow jumpmark)
to the first.
If "Cycle marks" is un-checked
i can only jump to the last mark
and must go to the top of the text on my own
to jump to the marks in the upper half.
;;Translate Cycle marks
cCycleMarks_Caption=Bookmark Option: ALT+Up/Down-Sprung zierkulierent
If this is right Jan, then
why is this in Confirmation section ?
And not in Editor - Behaviour?
Edited 1 time(s). Last edit at 2006-08-03 11:33 by Stefan.
Posted by: MrSpock | Date: 2006-08-03 16:49 | IP: IP Logged
Stefan:If this is right Jan, then
I agree that the location of the checkbox is a little misleading. I'd never look into "Confirmation" if I wanted to change the bookmark cycle behavior.
Posted by: Mark Baines | Date: 2006-08-03 19:42 | IP: IP Logged
Problem of not being able to select last 3-5 lines in various files, including txt, css, cfg etc file by clicking on left gutter persists from earlier versions. Turn off line wrapping and problem goes away.
I see now that it seems the longer the file, the larger the number of lines at the end that can't be selected. In one 376 lie file the last 73 lines can'e be selected!
I've reported this many times.
Thanks
Posted by: Mark Baines | Date: 2006-08-03 20:01 | IP: IP Logged
Still can't block comment a line in a css file.
It places /**/ at the begining of the line.
I have the following att he end of the cdd.def file:
[/*...*/ | Block comment]
thanks again.
Posted by: MrSpock | Date: 2006-08-03 22:27 | IP: IP Logged
Mark, you have to select the text you want to make a comment before hitting <Ctrl>+<Space>. Then it should work.
Posted by: Thomas | Date: 2006-08-04 07:03 | IP: IP Logged
thanks for your ongoing work with this tool.
Would you consider to replace the confusing three-state checkboxes with drop-down choices that clearly label the selected option (or radio buttons)?
That would a great usability improvement.
Thomas
Posted by: pspad | Date: 2006-08-04 08:44 | IP: IP Logged
MrSpock:I agree that the location of the checkbox is a little misleading. I'd never look into "Confirmation" if I wanted to change the bookmark cycle behavior.
OK. I moved it into Program behaviour
Posted by: Michael S | Date: 2006-08-04 11:18 | IP: IP Logged
the error at the compiler output LOG, described here:
forum.pspad.com
remains.
Kind regards
Michael S
Posted by: menet | Date: 2006-08-04 12:49 | IP: IP Logged
Can you try again to reproduce the problem that i have with the PSPad version bigger than 4.5.1 (standard version) where it was right. I have this problem with 2231, 2228 versions.
Starting a second PSPad on DOS prompt
- PSPad is not running
- open DOS window
- set directory to PSPad directory
- on DOS window call: PSPad.exe licence.txt (It runs PSPad and loads Licence.txt file)
- on PSPad, close the Licence.txt file
- on the same DOS window (do F3) to call again : PSPad.exe licence.txt
Then you should see my problem : PSPad is always with an empty window but the title is "PSPad - [pspad.exe licence.txt]"
If the second call on DOS was PSPad.exe /R licence.txt, then it gives also an empty window but the title is then "PSPad - [pspad.exe /R licence.txt]"
Note that without error, the licence.txt is in the window in Read-Only mode and the title is "PSPad - [c:\directory\pspad\licence.txt R/O]"
With the version 2227 (or 2223), it was OK for the licence.txt file in a second tab but it open also a first tab with PSPad.exe edited in hexa !
Do you reproduce this problem ?
Best regards
