You are here: PSPad forum > English discussion forum > PsPad inserts characters into the files
Posted by: idefix2 | Date: 2024-08-11 16:02 | IP: IP Logged
1.
I don't know exactly since when this happens, but whenever I open a file, PsPad appends an empty line to that file. It does not mark the file as changed, though, so the additional line is only saved to the disk if I make other changes to the file.
2. The second problem is more serious, but it does not heppen very often, somethiing like twice every week. Sometimes, a strange character (its always the same character) is inserted at the beginning of a line, most of the time (maybe even only in such a line) in a line that consists of only spaces and a closing bracket "}"
When I make changes in other places of the file and save the file, the saved file contains this garbage character (line 388 in the picture)
It's always the same character, and I think (I am not sure) that happens only with lines that contain a single closing bracket like in the picture. the "ÿ" obviously replaces the first space of the line, because the closing bracket remains aligned with the block above
Posted by: idefix2 | Date: 2024-11-13 18:54 | IP: IP Logged
Please can you do something about this problem? It is really ennoying.
If you need any kind of additional information, let me know what I should provide.
Posted by: marco.tiraferri | Date: 2025-02-20 15:39 | IP: IP Logged
idefix2:Please can you do something about this problem? It is really ennoying.If you need any kind of additional information, let me know what I should provide.
I hadthe same problem too, and now i go chinese chars too
Please resolve!!
Posted by: bodriop | Date: 2025-02-23 21:59 | IP: IP Logged
I have the same problem, any solution?
It is very annoying and problematic.
Posted by: pspad | Date: 2025-02-24 05:58 | IP: IP Logged
Solution will be new editor engine
