You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.7 (2437) English
Posted by: pspad | Date: 2012-01-30 18:35 | IP: IP Logged
Download links (2.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.7 (2433)
News
Program settings / System - new option Register as IE HTML viever. Files open from Temporary internet files witout extension will be open with HTML highlighter
Program settings / System - new option Internal browser in IE9 mode
In the menu File/Special added option Delete file history
Search for current word/selection cycles in file same as F3/Shift+F3
PHP highlighter - added keywords trait, insteadof
Ruller font is same as font editor
Into KeyMap was added command DeleteBOL (delete from cursor to begin of the line)
Added new keywords into COBOL highlighter
New user highlighter syntax definition for V+ include Code explorer
Code clips - fixed problem when selected text contains char '|'
Exception for Code format and user highlighter
HTML multihighlighter - PHP variable is marked include $ using doubleclick
File change detection was reverted into 4.5.4 version
Code clips - checkbox @K control - fixed default checked state
Fixed IE HTML viewer and Internal browser
Fixed block copy
Posted by: Manfred62 | Date: 2012-01-30 18:55 | IP: IP Logged
Hi Jan
just a question: what's the reason for the § between semicolon and pipe in the css.def?
Quote:background-color: %color%;§|
PSPad 4.5.9 (2525)
Posted by: pspad | Date: 2012-01-30 19:16 | IP: IP Logged
On the place of § char is pasted selected text
When you select some text and call clip color, it will surround selected text
Posted by: Blues48 | Date: 2012-01-30 19:26 | IP: IP Logged
Thanks for adding Delete to BOL.
I am still not able to use the custom colors in Color Translator as described here:
forum.pspad.com
The most annoying bug, however, is this one:
forum.pspad.com
I wish something could be done about it, because I have already messed up so many files that I almost get to the point of not using PSPad anymore. This bug is really dangerous, seriously.
Posted by: Manfred62 | Date: 2012-01-30 19:53 | IP: IP Logged
pspad:On the place of § char is pasted selected text
Hmm, tried this... but confusing eg. wrong?
example:
I write red, doubleclick (mark) it, choose clip color,
set § --> I get: color: red;red
any hints?
PSPad 4.5.9 (2525)
Posted by: pspad | Date: 2012-01-30 20:46 | IP: IP Logged
Manfred62:Hmm, tried this... but confusing eg. wrong?
example:
set § --> I get: color: red;redany hints?
Look at e.g. HTML bloxk comment clip and try it with selected text
Posted by: Manfred62 | Date: 2012-01-30 21:42 | IP: IP Logged
Hi Jan,
tested it. You have to change the § to this order
color: §%color%;|
then I get the correct function.
mark red, choose clip color, enter, enter
color: red;
will update my context files too.
regards Manfred
PSPad 4.5.9 (2525)
Posted by: Manfred62 | Date: 2012-01-31 18:30 | IP: IP Logged
Manfred62:Hi Jan,tested it. You have to change the § to this order
color: §%color%;|then I get the correct function.mark red, choose clip color, enter, enter
color: red;will update my context files too.
regards Manfred
just an update:color: %color%§;|
this also works. What's better? Any side-effects?
Manfred
PSPad 4.5.9 (2525)
Posted by: cebe | Date: 2012-02-07 17:11 | IP: IP Logged
Here is some HTML (4 & 5) missing tags (with closing tag !) :
<aside><audio><blockquote><button><canvas><cite><dd><dl><dt><fieldset><figcaption><figure><hgroup><label><legend><mark><quote><video>
I didn't list very specific tags, like <details>, <time>, <track>...
I have an old question : what's the ciphered method used for password in PSPadFTP.ini FTP ?
Thanks.
Posted by: pspad | Date: 2012-02-07 21:04 | IP: IP Logged
cebe:Hi,Here is some HTML (4 & 5) missing tags (with closing tag !) :
<aside><audio><blockquote><button><canvas><cite><dd><dl><dt><fieldset><figcaption><figure><hgroup><label><legend><mark><quote><video>I didn't list very specific tags, like <details>, <time>, <track>...
Thanks.
I used current PSPad and I found missing QUOTE and TRANCK only.
PSPad uses my own algorithm for passwords in FTP. I have to use algorithm what allows you code and decode.
