You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.1 (815) English
Posted by: Ilya | Date: 2024-03-19 05:25 | IP: IP Logged
DelphiErik:..I prefer to use the slash char like in many IDE's and editors (toggle line comment). Thanks.
+1
Posted by: MadCompie | Date: 2024-04-12 10:32 | IP: IP Logged
Compared to the latest 5.0.7, the editor method OpenFileFromFTP behaves differently (and works no longer)
It immediately asks where to save the file locally. When I choose "desktop" f.e. it saves the file but I receive a message that the file cannot be opened...
Posted by: pspad | Date: 2024-04-12 11:19 | IP: IP Logged
Open program settings / backup and check if the FTP temp file exists
Posted by: MadCompie | Date: 2024-04-15 14:49 | IP: IP Logged
Hi, the FTP map from backup does exist and has all rights - it's the same as for the local files.
With the same settings it works with the previous version but when applying the new version it no longer works.
Posted by: pspad | Date: 2024-04-15 15:25 | IP: IP Logged
It's a local folder?
Do you run PSPad without elevated rights?
Can you try restore PSPad.ini from your backup?
Posted by: MadCompie | Date: 2024-04-25 09:05 | IP: IP Logged
pspad:It's a local folder?
It is indeed a local folder.
My PSPAD is installed in personal directory c:\marc\pspad with all rights, so no elevation needed.
The INI file from version 815 was the same as from working version 779.
In the original thread I said "Compared to the latest 5.0.7, ..."
But I meant version 5.1.779: this version still works but the latest 815 doesn't.
Edited 1 time(s). Last edit at 2024-04-25 09:10 by MadCompie.
Posted by: tmtisfree | Date: 2024-05-29 08:35 | IP: IP Logged
Quote:It isn't problem. I will follow it
I totally second the suggestion to put a line in the Update control window about new strings to translate, maybe with a bit more neutral notice like:
"New string(s) added to translation files."
Posted by: arogl | Date: 2024-09-25 08:26 | IP: IP Logged
When highlighting text the last character of the text is doubled
I have enabled slategray for pspad and for the color scheme
I am using "FiraCode Nerd Font Mono" - Regular - 10 point
Posted by: Freeman | Date: 2024-10-24 08:31 | IP: IP Logged
In this version, when multiline tabs enabled and tab panel got multilined due to the number of files opened, it doesn't shrink back when files closed and just one line of tabs remained. It draws an empty line which takes space of screen height.
I don't remember, how build 812th behavior was.
Posted by: pspad | Date: 2024-10-24 08:32 | IP: IP Logged
Thank you for report
