You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.5.1 (815) English
Posted by: Ilya | Date: 2024-03-19 05:25 | IP: IP Logged
DelphiErik:..I prefer to use the slash char like in many IDE's and editors (toggle line comment). Thanks.
+1
Posted by: MadCompie | Date: 2024-04-12 10:32 | IP: IP Logged
Compared to the latest 5.0.7, the editor method OpenFileFromFTP behaves differently (and works no longer)
It immediately asks where to save the file locally. When I choose "desktop" f.e. it saves the file but I receive a message that the file cannot be opened...
Posted by: pspad | Date: 2024-04-12 11:19 | IP: IP Logged
Open program settings / backup and check if the FTP temp file exists
Posted by: MadCompie | Date: 2024-04-15 14:49 | IP: IP Logged
Hi, the FTP map from backup does exist and has all rights - it's the same as for the local files.
With the same settings it works with the previous version but when applying the new version it no longer works.
Posted by: pspad | Date: 2024-04-15 15:25 | IP: IP Logged
It's a local folder?
Do you run PSPad without elevated rights?
Can you try restore PSPad.ini from your backup?
Posted by: MadCompie | Date: 2024-04-25 09:05 | IP: IP Logged
pspad:It's a local folder?
It is indeed a local folder.
My PSPAD is installed in personal directory c:\marc\pspad with all rights, so no elevation needed.
The INI file from version 815 was the same as from working version 779.
In the original thread I said "Compared to the latest 5.0.7, ..."
But I meant version 5.1.779: this version still works but the latest 815 doesn't.
Edited 1 time(s). Last edit at 2024-04-25 09:10 by MadCompie.
