You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.1 (815) English
Goto Page: 1 2 3 4 Next
#1 PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-02-28 18:55 | IP: IP Logged
sourceforge.net
PSPad 64 bit version is EXPERIMENTAL. It doesn't contains scripting. In case of any problem use 32bb version.
SHA1 hash:
7be46eb0daefeff57627750525915cf2acb87400 pspad551b815.zip
8c7881aaa955def54bad2467d89643fac79dae44 pspad551b815x64.zip
Changes to 5.5.1 (812)
News:
New variable %MainProjFile% returns file name and path to main project file (if exists) otherwise name of active file
Delete Word function (Ctrl+Del) doesn't remove last word on the line
The last edited files didn't open automatically when PSPad start
FTP client - extended max. width of the date column
White toolbar background with dark IDE style
Other fixes reported by users
#2 Re: PSPad unicode 5.5.1 (815) English
Posted by: AD7 | Date: 2024-02-28 19:53 | IP: IP Logged
Zdravím,
bolo by možné pridávať, občas, aj link na VirusTotal.com alebo tak?
Vďaka.
www.virustotal.com
Celkom ma "zaskočila" grinning smiley prítomnosť PSPad-u na sf.net:
sourceforge.net
#3 Re: PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-02-28 20:10 | IP: IP Logged
ClamAV ma dost casto false positive
SF mi sami nabidli uloziste, tak proc ne
#4 Re: PSPad unicode 5.5.1 (815) English
Posted by: Henk | Date: 2024-02-29 20:52 | IP: IP Logged
For your information:
When closing the 64bit version build 815 I get the same Exception EAccessViolation in module PSPad.exe as in the 812 build.
I have overwritten all files in my current x64 PSP program directory with the files in the latest 32b ZIP-archive.
#5 Re: PSPad unicode 5.5.1 (815) English
Posted by: Sam8 | Date: 2024-03-01 12:37 | IP: IP Logged
Hello, everytime opening new version 815 (32bit) it is blocked by firewall of Norton Antivirus, because it is trying to access internet with an invalid digital sign.
Can you fix?
Why does it need to access internet when launching? is it correct or maybe the zipped version contains some malware in the code?
#6 Re: PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-03-01 12:48 | IP: IP Logged
Can you send me address what is PSPad trying to reach?
There is a https request to analytics (https://www.pspad.com/analytics)
Switch it off in the program settings / Update (on the bottom of page)
#7 Re: PSPad unicode 5.5.1 (815) English
Posted by: Sam8 | Date: 2024-03-02 14:41 | IP: IP Logged
I haven't the exact address, but Norton AV says it's trying to access host www.pspad.com at 77.78.105.77:443.
I think the biggest problem is that Norton says the program "does not have a digital signature", so it reports the program as a threat. Maybe it's something you can fix.
#8 Re: PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-03-03 18:18 | IP: IP Logged
PSPad has valid digital signature. You can check it in program properties
77.78.105.77 belongs to pspad.com domain (ping www.pspad.com)
So your Norton is paranoid and tells you lie
Edited 1 time(s). Last edit at 2024-03-03 18:20 by pspad.
#9 Re: PSPad unicode 5.5.1 (815) English
Posted by: Sam8 | Date: 2024-03-04 11:31 | IP: IP Logged
I don't know why, with previous versions up to 812 it never gave warnings of this type, only 815 version get that alert. Maybe a false positive.
#10 Re: PSPad unicode 5.5.1 (815) English
Posted by: pspad | Date: 2024-03-04 11:38 | IP: IP Logged
I guess it's false positive.
Disable anynymous statistics in the Program settings / Update as I wrote before
