You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.5.1 (787) English
Posted by: pspad | Date: 2023-06-01 11:44 | IP: IP Logged
As I wrote, I will fix it. Ctrl+Del will delete in your case with repeating press:
spaces
$url
spaces
spaces
$base_url
Posted by: Freeman | Date: 2023-06-02 15:56 | IP: IP Logged
Another bug: Ctrl+/ (comment/uncomment a line) never worked for me, in any language.
Posted by: Freeman | Date: 2023-06-02 18:51 | IP: IP Logged
Looks like auto-save doesn't work in 787.
Posted by: pspad | Date: 2023-06-04 09:24 | IP: IP Logged
Freeman:Another bug: Ctrl+/ (comment/uncomment a line) never worked for me, in any language.
Checked and it works. It's available for languages supporting line comment by inserting chars on the begin of line.
If you use PHP and HTML multihighlighter, it won't work, cause HTML doesn't support such form of comment.
For user defined languages is special box for line comment format.
Posted by: pspad | Date: 2023-06-05 08:26 | IP: IP Logged
Freeman:Looks like auto-save doesn't work in 787.
It was disabled when PSpad is minimized. I will remove this condition. But it works when you don't minimize PSPad
Posted by: Freeman | Date: 2023-06-06 14:24 | IP: IP Logged
pspad:If you use PHP and HTML multihighlighter, it won't work, cause HTML doesn't support such form of comment.
It doesn't work for UNIX Shell Script and Python for me. Is there any setting can affect this command? I just overwrite PSPad.exe when new release/beta released, and don't do anything with ini-files contain PSPad settings. May be there is some outdated setting which prevent command to work.
Posted by: Freeman | Date: 2023-06-06 14:45 | IP: IP Logged
Can it be because of keyboard layout? I found this Czech layout on Microsoft, looks very different from the mine. In Russia, we use standard US keyboard layout. If this shortcut depends on scan code, can it affect on that?
Posted by: pspad | Date: 2023-06-07 04:00 | IP: IP Logged
When you call this command from Menu Format, does it works?
Try to delete KeyMap.ini (with not running PSPad) or from the menu format/ KeyMap press default button and restart PSPad.
You can also change shortcut in the proram settings / KeyMap
Posted by: Freeman | Date: 2023-06-07 20:29 | IP: IP Logged
pspad:When you call this command from Menu Format, does it works?
Yes.
Deletion of KeyMan.ini didn't help, corresponding line in the ini itself is:
aComment=Ctrl+/
I use PSPad under Windows 7. But, as I remember, this hotkey never worked, even in PSPad 4.x under Windows XP (if it was existed in that, I don't remember).
One more annoying thing I've found: Ctrl+Backspace removes a lot of extra characters. When cursor is placed to the quote character, it Ctrl+Backspace all characters to the beginning of line:
vhosts_dir + "/phpMyAdmin"
It's unusable now too.
Posted by: pspad | Date: 2023-06-08 03:12 | IP: IP Logged
You can assign difderent shortcut for comment code
Regards the Ctrl+Del, its fixed already and will be available in the next build
