You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.7 (623) English
Posted by: pspad | Date: 2021-05-07 11:32 | IP: IP Logged
Professor Bernd:Are there indentation lines for VBScript? Is there something that needs to be set?
CodeFolding for another highlighters include VBScript will be available on weekend build
Posted by: tmpad | Date: 2021-05-07 17:44 | IP: IP Logged
Where can I set to see all line numbers and not only every 5th?
Edited 1 time(s). Last edit at 2021-05-07 17:44 by tmpad.
Posted by: pspad | Date: 2021-05-07 17:53 | IP: IP Logged
It was test only.
In the next build will be option in direct edit with defaut old behavior
Posted by: bluezero | Date: 2021-05-08 07:57 | IP: IP Logged
The macros got slower:
gyazo.com
Before it put the text in almost immediately.
Loading of the files look a bit slower too.
Its not a big problem just wanted you to know.
But there is a bigger problem. CTRL+Z removes lines that were not written. I noticed it earlier, but while testing the macro i could reproduce it:
gyazo.com
you see that the lines 35-37 were removed.
Posted by: pspad | Date: 2021-05-09 09:48 | IP: IP Logged
Play macro was speeded up, it should be immediate now
Undo is slower, but I will try to speed it too
I wasn't able to simulate UNDO bug.
