You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.6.1 (2711) English
Posted by: pspad | Date: 2016-03-09 20:02 | IP: IP Logged
Download links (2.9 MB):
code.fosshub.com
I am very sorry for slow development. I am overloaded with work in my job just now. I hope it will be OK soon again.
Changes to 4.6.1 (2707)
News
Scripting - new editor based function splitWindow([intetger]): integer. Returns or set editor window split: 0 - isn't splitted, 1 - split vertically, 2 - split horizontally
Search/Replace speed up
New action aFTPConnect (Shift+Ctrl+F) allows you connect to FTP with keyboard without mouse. It's available in the File menu, you can use it in scripting e.t.c.
Code explorer for STL - now parses functions with STRING [nn] parameter
Right edge line doesn't fit to ruller
File tabs - problem with whole text and high DPI (4k displays)
File change detection
FTP handles files with special chars in file name, e.g. FileName_14:33.txt
Edited 1 time(s). Last edit at 2016-03-10 12:11 by pspad.
Posted by: Bobf | Date: 2016-03-10 11:16 | IP: IP Logged
hello Jan,
many thanks for the new build, but my pspad shows 2711 instead of 2011.
#Bob
Posted by: Bobf | Date: 2016-03-10 11:23 | IP: IP Logged
another issue i have with this build is.
when you searching within a file and select [List], even the argument is multiple times in the file, it find nothing.
back to 2707 and it works.
#Bob
Edited 1 time(s). Last edit at 2016-03-10 11:23 by Bobf.
Posted by: pspad | Date: 2016-03-10 12:12 | IP: IP Logged
Bobf:hello Jan,many thanks for the new build, but my pspad shows 2711 instead of 2011.
#Bob
2011 is typo, correct version is 2711
Posted by: Bobf | Date: 2016-03-10 12:19 | IP: IP Logged
Thanks Jan,
what's about seach in files issue?
You are able to re-create it`
#Bob
Posted by: pspad | Date: 2016-03-10 12:32 | IP: IP Logged
Bobf:another issue i have with this build is.
back to 2707 and it works.#Bob
Thank you. I found a problem and fixed it. I hope another build will follow this weekend
Posted by: pspad | Date: 2016-03-10 12:34 | IP: IP Logged
Bobf:Thanks Jan,what's about seach in files issue?
You are able to re-create it`#Bob
Hello Bob. I do what I am able in my free time. As I remember it wouldn't be a problem to fix it.
