You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2320) English
Posted by: pspad | Date: 2008-06-10 16:16 | IP: IP Logged
gurbao:Hi,what is the reason for the new list logwindow?
I find it much harder to view large output when I have to scroll back and forth, up and down.
Or are there settings available to control the size of the log area?
Regards,
I am very sorry for it. I forgot to return it back when I tested it.
I upload fixed version. Download again 2320 build
Posted by: Funbug | Date: 2008-06-10 16:43 | IP: IP Logged
Colors for "Search Results" and "Search in Files" are still messed up when using white text on black background.
See here.
Posted by: Nelson | Date: 2008-06-10 17:15 | IP: IP Logged
Marten:Marten:After installing the patch I get the following message:The ordinal 968 could not be located in the dynamic link library LIBEAY32.dll
My OS is Windows XPSP3. Deleting the dll solves the problem.
My OS is XP SP3 and I got the same problem.
Deleting the dll also solves my problem.
Posted by: pspad | Date: 2008-06-10 17:28 | IP: IP Logged
Funbug:Colors for "Search Results" and "Search in Files" are still messed up when using white text on black background.
Sorry, but you see something about it in changes?
Posted by: pspad | Date: 2008-06-10 17:31 | IP: IP Logged
Nelson:Marten:After installing the patch I get the following message:The ordinal 968 could not be located in the dynamic link library LIBEAY32.dll
Try to download latest light OpenSSL binaris and put both DLLs into PSPad folder
Posted by: Funbug | Date: 2008-06-10 17:42 | IP: IP Logged
pspad:Funbug:Colors for "Search Results" and "Search in Files" are still messed up when using white text on black background.Sorry, but you see something about it in changes?
No, I just wanted to make sure that you are aware of this problem since you haven't commented on my last post. Never mind.
Edited 1 time(s). Last edit at 2008-06-10 17:43 by Funbug.
Posted by: MrSpock | Date: 2008-06-10 19:13 | IP: IP Logged
Since I upgraded to build 2320, the DLL option in the settings for the shell integration (context menu) is greyed out for me. I can only use the Registry option, although I double-checked that my normal user account has admin rights. The DLL is where it should be.
I recently installed Service Pack 3. Anyone else having this type of problem with Win XP SP3?
Posted by: pspad | Date: 2008-06-10 19:34 | IP: IP Logged
MrSpock:Since I upgraded to build 2320, the DLL option in the settings for the shell integration (context menu) is greyed out for me. I can only use the Registry option, although I double-checked that my normal user account has admin rights. The DLL is where it should be.
There is problem with me, sorry.
I add test to Vista 64 to disable DLL as shell handler. And I set test always to true to see behavior on my WinXP.
Build 2240 was updated second time tonight
Edited 1 time(s). Last edit at 2008-06-10 19:35 by pspad.
Posted by: MrSpock | Date: 2008-06-10 22:01 | IP: IP Logged
pspad:There is problem with me, sorry.
No problem at all. That's what beta builds are for.
Posted by: @msterdam | Date: 2008-06-11 06:13 | IP: IP Logged
Thank you again Jan, for this new update!
The KiXtart highlighter is fantastic now, including the correct handling of parameters and the friendly names of the different KiXtart components.
And what I also like very much is the new TextDiff per line
Kind regards,
Ed
