You are here: PSPad forum > Developer forum - new builds > PSPad and TopStyle Lite 3.50
Posted by: pspad | Date: 2008-07-01 15:08 | IP: IP Logged
Because new TopStyle Lite 3.50 version doesn't register itself as COM server, it isn't possible to use it in PSPad.
You have 2 ways how to do it:
1. install TopStyle Lite 3.10 and reinstal it with TopStyle Lite 3.50 without uninstall or simply replace files in TopStyle folder (EXE and DLL) with new version.
2. Download this smal package:
www.pspad.com
It contains 2 REG files. One reister TopStyle (both) in Windows registry second REG file delete registry entries.
You need to have administrator right to do it (right mouse and Run as administrator under Vista).
Edited 3 time(s). Last edit at 2020-05-29 18:29 by pspad.
Posted by: michal.kolesa | Date: 2008-10-03 18:55 | IP: IP Logged
Vzhledem k tomu, že nová verze TopStyle Lite 3.50 neregistruje jako server COM, není možné jej používat v PSPad.
Máte 2 způsoby, jak to udělat:
1. TopStyle Lite 3.10 nainstalovat znovu, a to s TopStyle Lite 3.50 bez odinstalovat nebo jednoduše nahradit soubory ve složce TopStyle (EXE a DLL) s novou verzí.
2. Download this smal package: Stáhněte si tento balíček Smal:
www.pspad.com
Jeden reister TopStyle (obojí) v registru systému Windows druhé REG soubor smazat položky registru.
Musíte mít práva správce, aby to udělal (pravé myši a spustit jako administrátor pod Vista).
S pozdravem
Michal Kolesa
Posted by: jokmontoya | Date: 2009-09-16 20:10 | IP: IP Logged
I have modified the TopStyle_registration.reg file, so it now works on spanish Windows. In spanish windows, "Program Files" is named "Archivos de programa" some paths in the reg file need to be modified, "C:\\PROGRA~1\\" to "C:\\ARCHIV~1\\" and "C:\\Program Files\\" to "C:\\Archivos de programa\\".
This is the code in the file TopStyle_registration.reg for Spanish windows:
Intructions in spanish:
(ES) Copia y pega el codigo que se encuentra entre las lineas, no incluidas, en un archivo de texto, renombra la extensión a ".reg" y ejecutalo haciendo doble click, esto hara que se registre debidamente el TopStyle Lite 3.5 para que PsPad lo detecte bien.
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TopStyleLite.Application]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TopStyleLite.Application\Clsid]
@="{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\LocalServer32]
@="C:\\ARCHIV~1\\Bradbury\\TSLite3\\TSLite3.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\ProgID]
@="TopStyleLite.Application"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\TypeLib]
@="{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9A0EB8C5-3ADB-11D3-BCEE-00C04F72DA55}\Version]
@="3.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}]
@="IApplication"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}\ProxyStubClsid]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{9A0EB8C3-3ADB-11D3-BCEE-00C04F72DA55}\TypeLib]
"Version"="3.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0]
@="TopStyle Lite Library"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0\0\win32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0\FLAGS]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.0\HELPDIR]
@="C:\\ARCHIV~1\\Bradbury\\TSLite3\\"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5\0\win32]
@="C:\\Archivos de programa\\Bradbury\\TSLite3\\TSLite3.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5\FLAGS]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{5C21BCD5-F27A-11D2-BB98-00C04F72DA55}\3.5\HELPDIR]
@="C:\\Archivos de programa\\Bradbury\\TSLite3\\"
The unregistration file, don't need to be modified.
(ES) El archivo para eliminarlo del registro no necesita ser modificado, puedes usar el que está en el fichero del post inicial.
Edited 1 time(s). Last edit at 2009-09-16 20:11 by jokmontoya.
Posted by: Hymer | Date: 2010-06-16 19:30 | IP: IP Logged
I downloaded and extracted TopStyle registration and unregister, but now I don't know what to do with them. I have TopStyle Lite 3.5 on my computer.
Posted by: carbonize | Date: 2010-06-23 19:35 | IP: IP Logged
Double click the register file and just allow it when asked.
Carbonize
Posted by: Bitz | Date: 2010-07-14 11:53 | IP: IP Logged
That is exactly what I needed, thank you.
Bitz
Posted by: tcblack | Date: 2011-09-01 14:07 | IP: IP Logged
For windows 7 X64 you'll have to edit the registration file and change progra~1 to progra~2. Also change "program files" to "Program files (x86)".
There are two of each.
Here's the final reg that worked for me:
REGEDIT4
@="C:\\PROGRA~2\\Bradbury\\TSLite3\\TSLite3.exe"
@="3.0"
@="IApplication"
"Version"="3.0"
@="0"
@="C:\\PROGRA~2\\Bradbury\\TSLite3\\"
@="C:\\Program Files (x86)\\Bradbury\\TSLite3\\TSLite3.exe"
@="0"
@="C:\\Program Files (x86)\\Bradbury\\TSLite3\\"
Edited 1 time(s). Last edit at 2020-05-29 18:28 by pspad.
