You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2320) English
Posted by: himila | Date: 2008-06-11 09:41 | IP: IP Logged
Marten:After installing the patch I get the following message:The ordinal 968 could not be located in the dynamic link library LIBEAY32.dll
you can change the name of the file "libssl32.dll" to "ssleay32.dll", i found the name "ssleay32.dll" is the original name from the compiler.
Edited 1 time(s). Last edit at 2008-06-11 09:42 by himila.
Posted by: pspad | Date: 2008-06-11 09:51 | IP: IP Logged
PSPad works with both names. Name depends of build author.
Posted by: himila | Date: 2008-06-12 02:36 | IP: IP Logged
pspad:PSPad works with both names. Name depends of build author.
But, after changing the name to "ssleay32.dll" the error didn't happen again. Or the "ssleay32.dll" file doesn't work anymore,beacause if you delete the file "ssleay32.dll",PSPad also doesn't show the error.
Posted by: pspad | Date: 2008-06-12 03:45 | IP: IP Logged
For secure FTP you need 2 libraries: libeay32.dll and (ssleay32.dll or libssl32.dll)
ssleay32.dll and libssl32.dll is same library with different name
Posted by: zeeric | Date: 2008-06-12 07:01 | IP: IP Logged
a little suggestion : il would be nice if we could go directly to the good dirctory from a file : for instance, a right click would whow "directory context"
It would allow to open a file, and with one clik, to open the tree (in the project view) at the directory which contain the file.
thanks for this very good editor
Posted by: MrSpock | Date: 2008-06-12 12:32 | IP: IP Logged
I guess the font button next to the log window should have a cursor hint.
Posted by: muthukrish_2000 | Date: 2008-06-16 05:41 | IP: IP Logged
I have a Javascript file which is placed under Script\JSCRIPT folder.I have given a module name for that script file.Everytime When i make any changes and give recompile scripts its giving an error "Module name isn't unique".There is only one Script file in that folder. Its not happening in previous build 2309.
Posted by: pspad | Date: 2008-06-16 06:17 | IP: IP Logged
muthukrish_2000:I have a Javascript file which is placed under Script\JSCRIPT folder.I have given a module name for that script file.Everytime When i make any changes and give recompile scripts its giving an error "Module name isn't unique".There is only one Script file in that folder. Its not happening in previous build 2309.
Module name have to be unique for all script, not JScript only
Check if you do'nt have backup of your script there.
PSPad takes all in JScript folder as scripts
Edited 1 time(s). Last edit at 2008-06-16 06:20 by pspad.
Posted by: papi | Date: 2008-06-16 09:29 | IP: IP Logged
Hello!
I think in this last version (2320) PSPad lost his possibility to recognize if a file modified outside of the editor... :( I checked, and this was working fine in the previous version.
I am using now the latest uploaded version from the version 2320.
BR,
P.
Posted by: papi | Date: 2008-06-16 09:34 | IP: IP Logged
Sorry, please forgot it. I do not understand this: now, as I switched back to the version 2320 again, it is working. I really do not understand what is going on, because earlier I saw that problem already twice (in completelly 2 different cases)...
papi:Hello!I think in this last version (2320) PSPad lost his possibility to recognize if a file modified outside of the editor... :( I checked, and this was working fine in the previous version.
I am using now the latest uploaded version from the version 2320.BR,
P.
