You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2303) English
#11 Re: PSPad unicode 4.5.4 (2303) English
Posted by: Lived | Date: 2008-02-12 12:27 | IP: IP Logged
Some strange things happens. ;)
1. PSP not running. Run PSP via TotalCommander(TC) by pressing F4 on any file (for simple, *.txt). All looks good.
2. PSP is running. Again in TC press F4 to edit file (one or another). Oops. In PSP 2(!) tabs,
1st tab - ...PSPad.exe
2nd tab - file.
3. In toolbar of TC, i have an icon for PSP. When doing drag&drop file on it, all fine, nor running PSP or not.
In previous beta's was good.
So, i don't know what to do/think. smiling smiley
P.S. sorry, for bad english language, translate.ru. sad smiley
#12 Re: PSPad unicode 4.5.4 (2303) English
Posted by: Marten | Date: 2008-02-12 16:09 | IP: IP Logged
Hi Jan,
In releases before 4.5.4 (build 2301) after compilation the editor was opend on the line of the first error. Is this option removed from the LOG window or is it a matter of a wrong configuration?
Regards,
Marten
#13 Re: PSPad unicode 4.5.4 (2303) English
Posted by: andybridges | Date: 2008-02-14 09:53 | IP: IP Logged
I have a bug here too with this latest build.
If I open two files and switch between them I sometimes see characters from the first file in the second one... It only happens when a line finishes with whitespace characters (e.g. a space or a tab)
[Tab 1]
hello, my name is Andy
I use PSPad. It's really useful
[Tab 2]
PSPad is useful.
I use it every day.
If I put a few spaces (I'm using "_" so you can see it, but it would actually be spaces) on the end of tab 2's first line I will *see*:
[Tab 1]
[Tab 2]
PSPad is useful.___n
I use it every day.__l
The characters only *appear* to be there - I can't select them and saving the file doesn't save it with those extra chars. It seems to be a graphical glitch rather than anything else. It's always just one character and it's what ever was in that position on screen before switching tabs.
#14 Re: PSPad unicode 4.5.4 (2303) English
Posted by: andybridges | Date: 2008-02-14 09:58 | IP: IP Logged
I'm also still seeing the "shift+hotkey" bug I was getting in the last full release.
Binding a script to "Shift+F5" for example causes the script file to be opened when you try and use that shortcut instead of executing it.
It doesn't happen if you bind Ctrl+Shift+Key or Ctrl+Alt+Shift+Key
#15 Re: PSPad unicode 4.5.4 (2303) English
Posted by: owilsky | Date: 2008-02-14 10:20 | IP: IP Logged
Yes, that's what I described in post #10.
Oliver Kötter
#16 Re: PSPad unicode 4.5.4 (2303) English
Posted by: fetis | Date: 2008-02-15 00:13 | IP: IP Logged
andybridges,
I have the same problem. I described it in this post
Edited 1 time(s). Last edit at 2008-02-15 00:14 by fetis.
#17 Re: PSPad unicode 4.5.4 (2303) English
Posted by: pspad | Date: 2008-02-15 06:51 | IP: IP Logged
fetis:
andybridges,
I hope new build will solve it. Wait for this weekend.
#18 Re: PSPad unicode 4.5.4 (2303) English
Posted by: ali.godo | Date: 2008-02-15 07:30 | IP: IP Logged
Hi, PSPad so great 4 me.
I have a question with the font display,
does it support word space setting ?
because when I set Font with courier 12pt, the word space to much space.
look like:
"P S P a d s o g r e a t ."
I hope it show look like
"PSPad so great."
thanks.
#19 Re: PSPad unicode 4.5.4 (2303) English
Posted by: nfree | Date: 2008-02-19 00:58 | IP: IP Logged
comments font style has been changed ...
I don't know why ;;
font size is smaller than before .
please ... check it .
smiling smiley
Edited 1 time(s). Last edit at 2008-02-19 00:58 by nfree.
#20 Re: PSPad unicode 4.5.4 (2303) English
Posted by: pspad | Date: 2008-02-19 17:40 | IP: IP Logged
nfree:
I don't know why ;;
smiling smiley
I don't understand. Screenshot please
