You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2303) English
Goto Page: 1 2 3 4 Next
#1 PSPad unicode 4.5.4 (2303) English
Posted by: pspad | Date: 2008-02-09 07:43 | IP: IP Logged
Download links (1.7 MB):
pspad.siliconhill.cz
Changes to 4.5.4 (2301)
News
scripting interface - you can set LOG window type with commands logSeTypeMemo and logSetTypeList
C++ highlighter - now is possible to set brackets color
FTP client - new column file type with sorting possibility
increased file load speed in case of Go to EOL in option was disabled
Corrections
Project from folder doesn't include files start with "."
HTML highlighter and Django templates - in some cases text was invisible
XML reformat - exception if XML doesn't start with entity
File name was changed to LowerCase if file was open as PSPad parameter
Search and Case Sensitive
ClipList doesn't show if program was set to StayOnTop
New text file save wih forst line longest then 250 chars
#2 Re: PSPad unicode 4.5.4 (2303) English
Posted by: mahira | Date: 2008-02-11 05:26 | IP: IP Logged
Hi Jan,
I experienced a strange error and switch back to 4.5.3 immediately.
while pressing enter at the end of a line including a $ sign, the new line begins with a $ sign and strange things happen.
for example;
$blabla<enter>
thanks,
Mahir
#3 Re: PSPad unicode 4.5.4 (2303) English
Posted by: pspad | Date: 2008-02-11 05:49 | IP: IP Logged
What syntax?
#4 Re: PSPad unicode 4.5.4 (2303) English
Posted by: Ilya | Date: 2008-02-11 05:51 | IP: IP Logged
mahira:
for example;
$blabla<enter>
I didn't see such behavior on my 2 PCs.
I use TclTk Highlighter on WinXPProf
#5 Re: PSPad unicode 4.5.4 (2303) English
Posted by: mahira | Date: 2008-02-11 07:10 | IP: IP Logged
in a perl file
after it happened, I close pspad, restart the pc and try again but same thing happen.
Then I install 4.5.3 again and the problem is gone...
What syntax?
#6 Re: PSPad unicode 4.5.4 (2303) English
Posted by: muthukrish_2000 | Date: 2008-02-11 09:20 | IP: IP Logged
Thanks for the new build with the scripting support for log window selection.smiling smiley
#7 Re: PSPad unicode 4.5.4 (2303) English
Posted by: girgink | Date: 2008-02-11 22:20 | IP: IP Logged
Hi!
I had the same problem with a plain ASCII file for which PSPad selected the syntax as XML.
By the way, last two versions (4.5.3 and 4.5.4) cause a lot of exceptions while editing long (more than several hundred characters) lines in PHP files, if syntax highlighting is active. It happens not all the time, but quite frequently and only when highlighting is on. When I close the exception dialog PSPad continues to run most of the time and let me turn off syntax highlighting, save the file and quit. If I don't turn off highlighting it continues to give the exception.
Regards,
#8 Re: PSPad unicode 4.5.4 (2303) English
Posted by: Nelson | Date: 2008-02-12 08:17 | IP: IP Logged
Hi, I got a problem about font displaying in this build.
In previous build (2301), PSPad displays text like this:
In this build (2303), PSPad displays text like this:
As you can see, it displays much better (better readability) in previous build.
I believe that's because you use the new editor component. Could you find a way to fix it?
PS: The settings are all the same in these two builds, I only change the PSPad.exe.
Edited 1 time(s). Last edit at 2008-02-12 08:19 by Nelson.
#9 Re: PSPad unicode 4.5.4 (2303) English
Posted by: girgink | Date: 2008-02-12 08:37 | IP: IP Logged
In the previous post I mentioned the exceptions occur when "syntax highlighting" is on. It should be "word-wrap", not "syntax highlighting". Sorry for this...
#10 Re: PSPad unicode 4.5.4 (2303) English
Posted by: owilsky | Date: 2008-02-12 11:31 | IP: IP Logged
Still not fixed:
owilsky:
This bug is still there:
I wrote a js script with this command:
addMenuItem("bla", "&Textbausteine", "ifcondition", "Shift+F11");
When I press Shift+F11 the script itself it opened, the function "ifcondition" is not executed.
Can you please fix this? This is very annoying.
Thanks for your hard work,
Oliver
Jan, can you at least confirm that it's a bug?
Oliver Kötter
