You are here: PSPad forum > Bug report / Hlášení chyb > frequently error
frequently error
Goto Page: Previous1 2 3
#21 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-28 09:07 | IP: IP Logged
i hope that this is not considered spam, but i just came to confirm that i've been running for 2 days without a crash now with the 32 bit 507 version
#22 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-28 11:59 | IP: IP Logged
i cannot edit the old post but i just opened another file and that broke the crash-free spree
after clicking "ok" the pspad process kept one whole cpu core to max and had to be ended in task manager
this time it was from a server via WinSCP, but i'm not sure if it makes a difference since the 64 bit version crashed on local fils as well
this is the commandline that is used to open pspad via winscp
Edited 1 time(s). Last edit at 2021-04-28 12:04 by poopiepoop.
#23 Re: frequently error
Posted by: pspad | Date: 2021-04-28 13:29 | IP: IP Logged
I don't like the last option - force text transfer, cause it can manipulate with file content, similar as FTP server does, but it shouldn't have influence of PSPad error sad smiley
#24 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-29 12:13 | IP: IP Logged
yeah i guess not :(
this time it happened when closing a local file tab from via doubleclick
Exception class:
Exception address:
Stack list, generated 29. 4. 2021 14:10:52
Thank you for your time to report this issue!
Please don't post exception report into the forum.
Send it to my support address (see Help > About).
And please add a short description what you did when exception occurred,
e.g.: close file (generic advice, nothing special to you)
In some cases I am else not able to recognize what caused exception.
- What did you do: ....<accurate step-by-step instructions here>..
- How did you do: by keyboard press, by menu, context menu, macro
- You had expected to get: ....
- But you got instead: .....
Thank you.
Program : C:\programs\pspad\PSPad.exe 5.0.7 (600)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A61,
Processor: Intel, Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz, 2400 MHz MMX
Display : 1920x1080 pixels, 32 bpp PPI: 120
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-30 09:04 by Stefan.
