You are here: PSPad forum > Bug report / Hlášení chyb > frequently error
frequently error
Goto Page: 1 2 3 Next
#1 frequently error
Posted by: aelledesign | Date: 2021-04-15 07:08 | IP: IP Logged
after the latest updates, I often get this error and have to close everything and lose unsaved data.
Tips?
Regards
#2 Re: frequently error
Posted by: pspad | Date: 2021-04-15 07:26 | IP: IP Logged
What do you mean "latest update"?
Latest full version 5.0.6 (589) from Aprith 8th?
#3 Re: frequently error
Posted by: aelledesign | Date: 2021-04-15 07:36 | IP: IP Logged
Since 5.0.5 (567) I have that error. In the beginning it happened once every 2 or 3 days now, with 5.0.6.589, it happens 5 or 6 times a day and I can no longer work via FTP
#4 Re: frequently error
Posted by: pspad | Date: 2021-04-15 08:16 | IP: IP Logged
Try please last 5.0.7 from PSPad developer forum.
You can backup your current PSPad folder, replace content and if you want, you can simply return it back
#5 Re: frequently error
Posted by: bluezero | Date: 2021-04-20 08:36 | IP: IP Logged
I am having the same problem:
Frequent crashes since 5.0.5, currently 5.0.6 (589)
I will give it a try with 5.0.7 as you suggested
#6 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-20 14:27 | IP: IP Logged
same thing happens to me, with the most recent versions (including the latest update, but was present 1-3 versions before too). using 64bit pspad. i have noticed this happens occasionally when i open a new file from within WinSCP as an external editor (never happened before these most recent versions)
Exception class:
Exception address:
Stack list, generated 20. 4. 2021 16:24:30
Please don't post exception report into forum.
Send it to my support address (see Help > About).
And please add short description what you did when exception occurred,
e.g.: close file (generic advice, nothing special to you)
In some cases I am else not able to recognize what caused exception.
Thank you.
Program : C:\programs\pspad\PSPad.exe 5.0.6 (589)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A61,
Processor: Intel, Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz, 2400 MHz MMX
Display : 1600x900 pixels, 32 bpp PPI: 96
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 3 time(s). Last edit at 2021-04-27 13:28 by Stefan.
#7 Re: frequently error
Posted by: bluezero | Date: 2021-04-20 15:17 | IP: IP Logged
507 still crashing...or not responding.
#8 Re: frequently error
Posted by: pspad | Date: 2021-04-20 15:25 | IP: IP Logged
Problem is maybe caused by memory manager. I will revert it to default one.
#9 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-25 12:32 | IP: IP Logged
thank you
which version should i roll back to in the mean time so it uses this old memory manager and the program doesn't crash?
#10 Re: frequently error
Posted by: pspad | Date: 2021-04-25 12:50 | IP: IP Logged
Try 5.0.4, but I think 5.0.7 won't make problems with start for you.
