You are here: PSPad forum > Bug report / Hlášení chyb > frequently error
frequently error
Goto Page: Previous1 2 3 Next
#11 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-25 16:32 | IP: IP Logged
i have just downloaded the 5.0.7 a few hours ago and it cashed when closing a file :( will try to downgrade to 5.0.4
#12 Re: frequently error
Posted by: pspad | Date: 2021-04-25 16:34 | IP: IP Logged
Few hours ago is old one. Try please the current 5.0.7
#13 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-25 17:37 | IP: IP Logged
same thing
Exception class:
Exception address:
Stack list, generated 25. 4. 2021 19:35:13
Program : C:\programs\pspad\PSPad.exe 5.0.7 (600)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A61,
Processor: Intel, Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz, 2400 MHz MMX
Display : 1600x900 pixels, 32 bpp PPI: 96
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 2 time(s). Last edit at 2021-04-27 09:52 by Stefan.
#14 Re: frequently error
Posted by: pspad | Date: 2021-04-25 19:16 | IP: IP Logged
I need more information.
You wrote you open document within WinSCP. PSPad is running or PSpad starts with your document?
Is the same behavior with 32b version of PSpad? You can replace files in your existing version. Enough is replace PSPad.exe, ssleay32.dll and libeay32.dll.
#15 Re: frequently error
Posted by: pspad | Date: 2021-04-25 19:23 | IP: IP Logged
Can you send me screenshot from your WinSCP editor settings for PSpad?
Do you open all files in one PSPad instance or for each file you open new PSPad instance?
#16 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-25 20:22 | IP: IP Logged
this time i have developed on a localhost after a long time and now i open files directly in the windows explorer, not WinSCP unfortunately. but i open all the files in the same PSPad instance always
i am running 64 bit version of pspad, should i try to switch to 32 bit?
i have noticed that this bug happens only when i am closing, or opening a file
#17 Re: frequently error
Posted by: pspad | Date: 2021-04-26 02:40 | IP: IP Logged
Please try 32b PSPad.
And one thing, try to delete pscache.bin file, it is located in pspad folder in case of portable version or in %appdata%\pspad folder in case of installed version
#18 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-26 09:19 | IP: IP Logged
been running the 32 bit version 507 without no problems for half a day so far!
(btw i don't have pscache.bin file anywhere in my system/portable pspad directory)
Edited 1 time(s). Last edit at 2021-04-26 09:20 by poopiepoop.
#19 Re: frequently error
Posted by: pspad | Date: 2021-04-26 09:37 | IP: IP Logged
OK. There is no difference for editing common files between 32b and 64b version. 64b version has no memory limit (2GB) as 32b application, so you can edit huge files, but 99,9% of people doesn't need it.
#20 Re: frequently error
Posted by: poopiepoop | Date: 2021-04-27 08:19 | IP: IP Logged
allright thanks! i will use 32 bit version, i always use EditPad for huge files anyways, as pspad is not optimized for that kind of thing
but perhaps you should reconsider putting down/modifying 64 bit anyways because people who don't know about this thread would download PSPad and then it would just keep crashing on them
Edited 2 time(s). Last edit at 2021-04-27 08:20 by poopiepoop.
