You are here: PSPad forum > Bug report / Hlášení chyb > Re: Unwanted and sudden converting to strange characters
#41 Re: Unwanted and sudden converting to strange characters
Posted by: pspad | Date: 2021-05-05 08:12 | IP: IP Logged
Please update to current 5.0.7
#42 Re: Unwanted and sudden converting to strange characters
Posted by: stanislav.mikusek | Date: 2021-06-05 21:07 | IP: IP Logged
I'm working all day with PsPad 64b 5.0.7(647), no bug occurred.
#43 Re: Unwanted and sudden converting to strange characters
Posted by: Gorlash | Date: 2021-06-08 02:01 | IP: IP Logged
Wow, not even two hours into using V5.07, and I got bitten by this bug...
I don't seem to be able to copy the entire trashed line, which is some 280 characters long. So here is an image of the entire trash-line:
www.flickr.com
Here is what the code looked like before being pspad-ed:
printf("Last logon: %s [%"PRIu64"]\n", ctm, (u64) max_logon_time) ; //lint !e571
#endif
// look at current time
Here is what the trashed section looks like in a hex dump:
023A0: 20 20 20 70 72 69 6E 74 66 28 22 4C 61 73 74 20 | printf("Last |
023B0: 6C 6F 67 6F 6E 3A 20 25 73 20 5B 25 22 50 52 49 | logon: %s [%"PRI |
023C0: 75 36 34 22 5D 5C 6E 22 2C 20 63 74 6D 2C 20 28 | u64"]\n", ctm, ( |
023D0: 75 36 34 29 20 6D 61 78 5F 6C 6F 67 6F 6E 5F 74 | u64) max_logon_t |
023E0: 69 6D 65 29 20 3B 20 20 2F 2F 6C 69 6E 74 20 21 | ime) ; //lint ! |
023F0: 65 35 37 31 0D 0A 20 20 20 0D 0A 20 20 20 0D 0A | e571.. .. .. |
02400: 23 65 3F 3F 69 66 00 4D 00 00 3F 3F 00 00 00 00 | #e??if.M..??.... |
02410: 00 00 3F 00 00 00 00 00 00 00 00 00 04 00 3F 3F | ..?...........?? |
02420: 3F 3F 00 00 00 00 00 00 49 00 3F 3F 00 00 00 00 | ??......I.??.... |
02430: 3F 3F 3F 00 00 00 00 00 00 00 01 00 04 00 3F 3F | ???...........?? |
02440: 00 00 00 00 00 00 6E 00 6E 00 3F 3F 00 00 00 00 | ......n.n.??.... |
02450: 3F 3F 3F 00 00 00 00 00 00 00 3F 02 01 00 02 00 | ???.......?..... |
02460: 0D 0A 00 6E 75 49 74 65 6D 00 3F 3F 00 00 00 00 | ...nuItem.??.... |
02470: 3F 3F 3F 00 00 00 00 00 00 00 3F 4A 3F 3F 05 00 | ???.......?J??.. |
02480: 08 00 00 00 65 73 00 61 79 00 3F 3F 00 00 00 00 | ....es.ay.??.... |
02490: 3F 3F 3F 00 00 00 00 00 00 00 3F 02 01 00 03 00 | ???.......?..... |
024A0: 4E 34 38 00 00 74 72 61 79 00 3F 3F 00 00 00 00 | N48..tray.??.... |
024B0: 3F 3F 3F 00 00 00 00 00 00 00 3F 02 01 00 09 00 | ???.......?..... |
024C0: 50 6F 70 75 70 53 61 76 65 00 3F 3F 00 00 00 00 | PopupSave.??.... |
024D0: 3F 3F 3F 00 00 00 00 00 00 00 3F 02 01 00 03 00 | ???.......?..... |
024E0: 4E 33 38 00 69 63 6B 00 00 00 3F 3F 00 00 00 00 | N38.ick...??.... |
024F0: 3F 3F 3F 00 00 00 00 00 00 00 3F 02 01 00 09 0D | ???.......?..... |
02500: 0A 20 20 20 0D 0A 20 20 20 2F 2F 20 20 6C 6F 6F | . .. // loo |
02510: 6B 20 61 74 20 63 75 72 72 65 6E 74 20 74 69 6D | k at current tim |
02520: 65 0D 0A 20 20 20 5F 74 7A 73 65 74 28 29 3B 0D | e.. _tzset();. |
So it is only the #endif line which was destroyed...
My OS info:
Edition Windows 10 Pro
Version 20H2
Installed on ‎02/‎08/‎21
OS build 19042.928
Experience Windows Feature Experience Pack 120.2212.551.0
I'm editing two .cpp files and one .htm file
#44 Re: Unwanted and sudden converting to strange characters
Posted by: stanislav.mikusek | Date: 2021-06-11 10:34 | IP: IP Logged
After a week of working with the 5.0.7 version, the bug appears. Damn.
Never mind, PsPad is the best anyway. I'm checking ascii 0 in saved files.
#45 Re: Unwanted and sudden converting to strange characters
Posted by: tfs | Date: 2021-06-15 13:51 | IP: IP Logged
I have seen this problem too. I save a php file but when I try to excetute it, it fails. I open the file and see that some part of code is converted into strange characters.
#46 Re: Unwanted and sudden converting to strange characters
Posted by: stanislav.mikusek | Date: 2021-06-20 21:22 | IP: IP Logged
I'v bug only in files with a UNIX end of line.
I also have files with windows CR LF, there isn't problem.
I changed the style of work - converting a UNIX file to WINDOWS version for PSPad and after changing convert back.
No bug appears.
#47 Re: Unwanted and sudden converting to strange characters
Posted by: Gorlash | Date: 2021-06-21 00:37 | IP: IP Logged
d
Edited 1 time(s). Last edit at 2021-06-21 00:37 by Gorlash.
#48 Re: Unwanted and sudden converting to strange characters
Posted by: Gorlash | Date: 2021-06-21 00:39 | IP: IP Logged
stanislav.mikusek:
No bug appears.
Sadly, as can be seen in my recent hex dump of my most recent experience with this bug, all of my newlines are DOS/Windows newlines (CR/LF), so that observation is not definitive for this bug...
#49 Re: Unwanted and sudden converting to strange characters
Posted by: stanislav.mikusek | Date: 2021-06-29 13:18 | IP: IP Logged
Oops, the bug in CR/LF file. It doesn't help.
#50 Re: Unwanted and sudden converting to strange characters
Posted by: akiuni | Date: 2021-07-19 09:10 | IP: IP Logged
This bugs is really annoying.
I'm using 5.0.7(665), the bug appears very often when closing a file (a tab), My language is Python.
Hope you will find a solution very quickly because it's occurig multiple times a day and corrups my scripts, which makes me thinking to change for another sofware.
