You are here: PSPad forum > English discussion forum > Error: Out of memory
Posted by: maki | Date: 2014-09-05 15:14 | IP: IP Logged
Hmmm...
At this time shows 10 MB of RAM and I have 100 open tabs with VERRRRYYY large texts.
So what's the problem?
Open(LARGE TXT) VS Copy/Paste(LARGE TXT) -It's not the same thing?
Posted by: maki | Date: 2014-09-05 15:17 | IP: IP Logged
This is probably a bug.
Stack list, generated 2014-09-05 17:24:56
Hi makinero, please do not post such lists to the forum.
Send them to Jan to mail address found in PSPad Help About.
Thank you.
Edited 2 time(s). Last edit at 2014-09-06 21:57 by Stefan.
Posted by: maki | Date: 2014-09-05 15:29 | IP: IP Logged
Read of address 0000001C
Posted by: pspad | Date: 2014-09-05 15:50 | IP: IP Logged
I explained you the reason. if you use task manager to see memory, add column paged pool to see whole memory for each process.
Posted by: pspad | Date: 2014-09-05 16:16 | IP: IP Logged
You see part of the occupied memory only. Add column pagged pool (menu View / Select columns)
Or do you really think if you open 100+ big files as you wrote, you will occupy 600MB of RAM?
Posted by: maki | Date: 2014-09-05 16:27 | IP: IP Logged
104 open TAB !!!
I could prove it but I can not show screen due to private bookmark names.
Example 2:
300 MB (TXT) - (Out Of Memory) Russian chars name
400 MB (TXT) - ( Little Memory) Normal chars name
Edited 4 time(s). Last edit at 2014-09-05 16:30 by maki.
Posted by: pspad | Date: 2014-09-05 16:36 | IP: IP Logged
PSPad works internally in unicode. If you have ansi file 400MB, it will consum 800MB of RAM (each char 2 bytes).
Don't forget for UNDO buffer in PSPad if you paste some text.
Display column pagged pool in task manater I mentioned in my previous answer.
Posted by: maki | Date: 2014-09-05 17:22 | IP: IP Logged
305 MB TXT UTF-8
Edited 1 time(s). Last edit at 2014-09-05 17:30 by maki.
Posted by: pspad | Date: 2014-09-05 17:46 | IP: IP Logged
Can't open doesn't mean there isn't enough memory, but there musty be another reason. E.g. file is locked by another application.
300MB UTF-8 is about 500MB of RAM in UTF-16
