You are here: PSPad forum > English discussion forum > project folder template
Posted by: tsaari | Date: 2014-09-05 13:57 | IP: IP Logged
I frequently need to create new release folders in my project. Each new release needs the same sub-folder tree. Is there a way to create a template file to add folders to a project using a specified tree?
For example:
+ R3.3
+ DB 1
+ Local
+ SVN
+ DB 2
+ /home/...
+ bin
+ sql
+ SVN
I tried searching the forum, but could find no similar topics.
Thanks.
Ted
Posted by: pspad | Date: 2014-09-05 14:19 | IP: IP Logged
You can create new project from folder or copy project file and edit base folder. Project is simple text file. Folder levels are made by tabulator char (0x9)
