You are here: PSPad forum > English discussion forum > open locked file as read-only
Posted by: Tsjoecha | Date: 2015-08-28 07:45 | IP: IP Logged
I love pspad, but sometimes I want to consult a locked file - for example a busy logfile from an active process. I never intend to change its data, but want to be able to search for error messages.
As a workaround, I make a copy of the given file, and open that instance. After consultation, I delete the copy again.
Is there a possibility to open locked files in pspad?
OS : win7 64bit. Latest version of pspad. (I think it used to work with some ancient version, but can't test that anymore)
Thx!
Posted by: pspad | Date: 2015-08-28 08:39 | IP: IP Logged
If file is locked (open exclusive) with any proces, other proces can't read it.
Posted by: Freeman | Date: 2015-08-31 22:02 | IP: IP Logged
Tsjoecha:a busy logfile from an active process.
You can use built-in viewer from FAR Manager (F3).
Posted by: Tsjoecha | Date: 2015-09-04 11:45 | IP: IP Logged
Quote:If file is locked (open exclusive) with any proces, other proces can't read it.
I can open those files in notepad though...
Edited 1 time(s). Last edit at 2015-09-04 11:46 by Tsjoecha.
Posted by: pspad | Date: 2015-09-04 12:01 | IP: IP Logged
Tsjoecha:Quote:If file is locked (open exclusive) with any proces, other proces can't read it.I can open those files in notepad though...
I need any example to simulate this behavior. Are you possible to tell me how to get any of your locked file? E.g. some system log...
Posted by: hhoefling | Date: 2015-09-04 13:18 | IP: IP Logged
Jan,
I Think PSPad try's to open any file in R/W Mode.
if open R/W does not successs try to open in R/O Mode.
by HH
Posted by: Tsjoecha | Date: 2015-09-04 15:20 | IP: IP Logged
I have the issue only with openedge logic, which I use all day long.
In fact, I make a stream to which I write data, and which I follow up with cygwin tail -f command. Sometimes though, I have to scroll back to check some "ancient" data.
Posted by: pspad | Date: 2015-09-04 16:11 | IP: IP Logged
To make some tests I need any such locked file. So I need step by step how to create such locked file.
Posted by: Tsjoecha | Date: 2015-09-07 11:59 | IP: IP Logged
As I told, I use openedge, and you'll need a licence to be able to do exactly what I do.
On msdn however, I found this article. I guess it will do a similar thing, as it works with streams as well.
Posted by: pspad | Date: 2015-09-07 12:58 | IP: IP Logged
I am using streams to open files. I don't do nothing exclusive, cause I need to read content of the file only.
This is reason, why I need anything (there is not necessary to have OpenEdge) what PSpad isn't able to open but others do.
