You are here: PSPad forum > English discussion forum > print of selected lines with the number found in the file
#1 print of selected lines with the number found in the file
Posted by: paul2015 | Date: 2015-09-09 11:44 | IP: IP Logged
- When a selection is done, is it possible to preview the result of the print, and not all the file?
- When a selection is done, is it possible to print the line number found in the file?
Example: A file has 4 lines.
Line 1
Line 2
Line 3
Line 4
The selected lines are Line 3 and 4.
Instead of the following result,
1 Line 3
2 Line 4
I hope to see the following result:
3 Line 3
4 Line 4
Thanks in advance for your help.
Paul2015
#2 Re: print of selected lines with the number found in the file
Posted by: pspad | Date: 2015-09-09 12:08 | IP: IP Logged
No. In the print dialog is decision what do you want to print - whole file / pages / selection. In the print preview I don't know yet what user wants to print.
#3 Re: print of selected lines with the number found in the file
Posted by: paul2015 | Date: 2015-09-11 09:17 | IP: IP Logged
Thanks for your reply to the first part of the message.
If this function would be implemented, the dialog should take into account the information : all file or some pages or the selection.
What about of the second part of the message, the lines numbers in the print?
Best regards
Paul2015
