You are here: PSPad forum > English discussion forum > open locked file as read-only
Posted by: Tsjoecha | Date: 2015-09-08 08:30 | IP: IP Logged
My logfile is written from withing openedge, through a stream. So, you have to to be able to write a stream (probably exclusive), and then try to open that file in PSpad. (as I understand, through a stream as well)
Posted by: pspad | Date: 2015-09-08 08:45 | IP: IP Logged
If application writes to stream with exclusive access, no other application has access to it. As example you can take operating system swapfile.
There is several option - you can open stream with exclusive write - it means other application can read but can't write. I don't know how OpenEdge creates it's log.
As easier imagination see this topic:
msdn.microsoft.com
Edited 2 time(s). Last edit at 2015-09-08 08:48 by pspad.
Posted by: Tsjoecha | Date: 2015-09-10 08:43 | IP: IP Logged
I don't know neither...
A standard stream is explained here:
documentation.progress.com
There is also a similar log-file system :
As notepad and others can read it, I think it is something like exclusive write, but open for reading for everyone (except pspad )
Posted by: pspad | Date: 2015-09-11 10:46 | IP: IP Logged
I am using FileStreams with OpenRead + ShareDenyNone mode
Each File stream in Windows uses WinApi CreateFile
OpenRead requests read only access and ShareDenyNone means PSPad doesn't request any lock (reading, writing).
I will try to change it a little, we will see. I tested it with locked files and I was able open any file what Notepad is able to open too.
There must be some other access, cause e.g. Lister in Total Commander is able to open file even others are not.
Posted by: Tsjoecha | Date: 2015-09-17 08:29 | IP: IP Logged
Is this allready foreseen in version 4.6.0 (2671)? Anyhow, there, it doesn't work
Posted by: pspad | Date: 2015-09-17 09:04 | IP: IP Logged
Sorry, but I am using standard file stream access without requesting any lock.
Without test and play with your special locked file I am not able to do anything.
I was able to open any file as other editors. If you tell me any Windows system file what PSPad isn't able to open and other editors can, I can do more.
Posted by: Tsjoecha | Date: 2015-09-17 13:36 | IP: IP Logged
I found a very simple test case.
You create a plain text file, let's say c:\test\file.txt
You open this file with LibreOffice Writer (www.libreoffice.org) or Ms Word (I tested with 2007)
You try to open the file simultanously with PsPad:
Error
Cannot open C:\test\file.txt
Cannot open file "C:\test\file.txt". The process cannot access the file because it is being used by another process
OK
Notepad works just fine...
I hope you can simulate this case.
Posted by: pspad | Date: 2015-09-17 17:06 | IP: IP Logged
I did this test. File was open with Word.
Notepad open this file.
PSPad open this file too. I tested open file with explorer context menu / Open in PSPad (integrated with DLL library), tested with running PSPad and it's Open file dialog, tested with running PSPad and Drag/Drop file to PSPad.
In all cases was file open in PSPad without any problem.
How do you open your file?
Posted by: Tsjoecha | Date: 2015-09-18 06:45 | IP: IP Logged
Tried all 3 methods... 3 time "file is locked" message.
I use win 7 64 bit English, all windows updates are installed.
Pspad had the Dutch user interface.
Posted by: Tsjoecha | Date: 2015-09-18 06:53 | IP: IP Logged
Ok, I found a setting where the context menu is through dll of via registry. Mine was as registry. I changed it, and now the word locked file opens just fine.
Unfortenately, my logfiles created through openedge are still locked
update : when I open the text file with Libreoffice writer, the lock persists.
Edited 1 time(s). Last edit at 2015-09-18 06:55 by Tsjoecha.
