You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2417) English
Goto Page: 1 2 3 4 5 6 7 Next
#1 PSPad unicode 4.5.5 (2417) English
Posted by: pspad | Date: 03/14/2011 19:55 | IP: IP Logged
Download links (1.9 MB):
pspad.siliconhill.cz
pspad.cincura.net
7ZIP archiv contains PSPad.EXE and language files only. Unpack it with subfolders and replace existing files from the last full release
Changes to 4.5.5 (2415)
News
FoxPro - new code explorer
File backup into designated folde includes drive letter
Code explorer trims redundant spaces
Autocomplete is case sensitive now
HTML5 support - added missing tags
menu Edit / Conversion - items was changed to actions. You can assign shortcuts, use conversion in scripts
handled exception in Highlighter settings
fixed Tcl/Tk variable highlight
fixed File tabs draw
Autocomplete works only if PSPad is active
work directory release when PSpad is minimized to tray
#2 Re: PSPad unicode 4.5.5 (2417) English
Posted by: PGomersall | Date: 03/14/2011 20:24 | IP: IP Logged
Jan,
The folder handle issue (work directory release when PSpad is minimized to tray) is still present in 2417.
W7 x64 Ent
Pete
#3 Re: PSPad unicode 4.5.5 (2417) English
Posted by: PGomersall | Date: 03/14/2011 21:27 | IP: IP Logged
Jan,
I did more testing this handle lock only seemed to be present the first time I ran 2417. Maybe it was just a glitch. Opening and closing PSPad a few more time I now cannot replicate the issue.
Pete
#4 Re: PSPad unicode 4.5.5 (2417) English
Posted by: PGomersall | Date: 03/15/2011 04:06 | IP: IP Logged
Sorry Jan for multiple posts, but I have done several tests now on multiple systems - the working directory release is inconsistent upon minimizing to the system tray after the document is closed. It sometimes release and not others. I cannot work out any pattern.
Pete
#5 Re: PSPad unicode 4.5.5 (2417) English
Posted by: pspad | Date: 03/15/2011 05:35 | IP: IP Logged
I will try to make some investigation
#6 Re: PSPad unicode 4.5.5 (2417) English
Posted by: tyzio | Date: 03/15/2011 09:12 | IP: IP Logged
Jan, thanks for the new build. I checked the TCL/TK issues which I reported previously, and they work fine except code browser for classes. I don't see classes tree in code browser.sad smiley
Anyhow, I really appreciate the work which you did to make PsPad Tcl friendlysmiling smiley
#7 Re: PSPad unicode 4.5.5 (2417) English
Posted by: RickH | Date: 03/15/2011 14:44 | IP: IP Logged
Still having the "File contents were changed. Reload?" issue with network files when returning to PSPad from another application after saving a file. Which is something I may do several times a minute when styling a web page, for instance.
I think the last version without the problem was 2411.
Is there perhaps something in the settings I'm missing?
#8 Re: PSPad unicode 4.5.5 (2417) English
Posted by: vbr | Date: 03/15/2011 18:08 | IP: IP Logged
RickH:
Well,
there is quite a dangerous "solution" to this there in
Settings: Direct edit: [Special settings]
CheckDocChanges=0
default is CheckDocChanges=1
with this check disabled, you have to ensure, that your file won't be modified from outside while it is open in PSPad, otherwise these changes would be lost as PSPad would directly save the internally available older file content.
hth,
#9 Re: PSPad unicode 4.5.5 (2417) English
Posted by: RickH | Date: 03/15/2011 18:46 | IP: IP Logged
Good enough. That's no problem for me, as I'm the only one working on the network. Which solely exists to have a "real" webserver for development/testing purposes. (XAMPP, et al go only so far.)
I was getting (somewhat) used to it, but the alert was still driving me nuts. Thanks.
#10 Re: PSPad unicode 4.5.5 (2417) English
Posted by: pspad | Date: 03/15/2011 20:48 | IP: IP Logged
RickH:
Are you able to exactly describe your network? I can try to simulate it on NAS with SAMBA. There can be problem if network drive will return different timestamp when you save file and when you read it again.
