You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2405) English
Goto Page: 1 2 3 4 5 6 7 8 Next
Posted by: pspad | Date: 2010-12-12 21:35 | IP: IP Logged
Download links (1.9 MB):
pspad.siliconhill.cz
pspad.cincura.net
7ZIP archiv contains PSPad.EXE and language files only. Unpack it with subfolders and replace existing files from the last full release
Changes to 4.5.5 (2401)
News
Search/Replace - PSPad will keep position when nothing is found
Search file from log priority change - PSpad search in compiler folder first, then in project and open files
File detection mechanism was rewriten
C++ code explorer
Posted by: carbonize | Date: 2010-12-12 22:08 | IP: IP Logged
Cincura server doesn't know what a 7z file is and so is not sending the correct header.
Carbonize
Posted by: MrSpock | Date: 2010-12-12 23:25 | IP: IP Logged
carbonize:Cincura server doesn't know what a 7z file is and so is not sending the correct header.
Yeah, the 7z file is sent as text. Most browsers will open it as "garbled text" consequently. The file can be saved in the browser via the normal "Save as ..." functionality, but it is quite confusing for someone who isn't familiar with this kind of problem.
Thanks for the new build, btw. I love the automatic autocompletion--however pleonastic this may sound. ;)
Posted by: pspad | Date: 2010-12-13 04:30 | IP: IP Logged
You can use context menu and "save target as..."
Posted by: stefangabos | Date: 2010-12-13 14:35 | IP: IP Logged
A small bug that it has been persisting for a while: if I select a *single* line and press CTRL-H (Replace) the "Scope" it's set to "Global" rather than "Selected text".
Posted by: pspad | Date: 2010-12-13 15:47 | IP: IP Logged
stefangabos:A small bug that it has been persisting for a while: if I select a *single* line and press CTRL-H (Replace) the "Scope" it's set to "Global" rather than "Selected text".
This is behavior by design, not a bug. And user wish.
Find more users who will want to change it and I will change it or make it optional.
Posted by: MadCompie | Date: 2010-12-13 17:21 | IP: IP Logged
global replace: when >1 line selected the scope will be automatically "selected text" = OK
so this only applies when only 1 line selected
Posted by: pspad | Date: 2010-12-13 18:44 | IP: IP Logged
MadCompie:global replace: when >1 line selected the scope will be automatically "selected text" = OK
And why did you write it here again? I answered same to stefangabos already.
Posted by: kosthala | Date: 2010-12-13 21:59 | IP: IP Logged
pspad:Fixes:
C++ code explorer
The fix is incomplete, it doesn't shows static functions.
Posted by: pspad | Date: 2010-12-14 05:03 | IP: IP Logged
kosthala:The fix is incomplete, it doesn't shows static functions.
I need code examples.
