You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2405) English
#11 Re: PSPad unicode 4.5.5 (2405) English
Posted by: stefangabos | Date: 2010-12-14 11:58 | IP: IP Logged
stefangabos:
A small bug that it has been persisting for a while: if I select a *single* line and press CTRL-H (Replace) the "Scope" it's set to "Global" rather than "Selected text".
This is behavior by design, not a bug. And user wish.
Find more users who will want to change it and I will change it or make it optional.
but it does not have any sense. if i have selected text than I expect the replace to refer to the selected text...
#12 Re: PSPad unicode 4.5.5 (2405) English
Posted by: pspad | Date: 2010-12-14 12:42 | IP: IP Logged
If something doesn't make sense to you, it doesn't mean that it's wrong.
I told you. Find several people who will agree with you and i will make it optional
#13 Re: PSPad unicode 4.5.5 (2405) English
Posted by: stefangabos | Date: 2010-12-14 14:11 | IP: IP Logged
smiling smiley i can't "find" other people. the vast majority of users are not hard-core users. probably very few people ever use the vast majority of an editor's feature. anyways, i'll leave it be...
don't get me wrong - i use pspad since i can't remember (6 or 7 years now) and it's a great editor.
#14 Re: PSPad unicode 4.5.5 (2405) English
Posted by: mdl | Date: 2010-12-14 14:40 | IP: IP Logged
kosthala:
The fix is incomplete, it doesn't shows static functions.
I need code examples.
Just send a screen shot to your email to show the scenario.
Thanks. smiling smiley
#15 Re: PSPad unicode 4.5.5 (2405) English
Posted by: pspad | Date: 2010-12-14 14:49 | IP: IP Logged
mdl:
I wish you to have all source code on internet examples in pictures tongue sticking out smiley
Please spare my time and send me source as text.
#16 Re: PSPad unicode 4.5.5 (2405) English
Posted by: Manfred62 | Date: 2010-12-14 17:21 | IP: IP Logged
Hi Jan
You had forgotten to delete the following:
Quote:
In settings/ system integration:
there's no translation for
Editor pro Total Commander?
regards Manfred
PSPad 4.5.9 (2525)
#17 Re: PSPad unicode 4.5.5 (2405) English
Posted by: mdl | Date: 2010-12-14 17:27 | IP: IP Logged
mdl:
grinning smileytongue sticking out smiley sent it.
smoking smiley
#18 Re: PSPad unicode 4.5.5 (2405) English
Posted by: myf | Date: 2010-12-14 17:35 | IP: IP Logged
stefangabos:
stefangabos:
Would you like to have 'Selection only' preselected by default even if your selection contains a single word? Or even a single character?
Dunno how much 'hardcore' I am, but I quite appreciate current behaviour: if my selection does not overlap a line scope, replace is 'Global' by default. This fits the case you are writing about: selection is form the start of line to its end, and no further. I usually select a line by {2×home}{shift+down} keystroke sequence (and, CMIIW, there is no built-in action for 'select line' operation in PSPad). In this case selection contains line-break and thus 'Selection only' is preselected, what typically fits exactly my needs. You may try to do it this way too, maybe you'll like it.
#19 Re: PSPad unicode 4.5.5 (2405) English
Posted by: Manfred62 | Date: 2010-12-14 22:14 | IP: IP Logged
Hi Jan
The file-tabs are now shown above the toolbar? In older versions the toolbar always stays above the file-tabs. Looks a little bit strange now...
EDIT: sorry, problem solved.
Changed settings, restart, now its ok.
regards Manfred
PSPad 4.5.9 (2525)
Edited 1 time(s). Last edit at 2010-12-14 22:19 by Manfred62.
#20 Re: PSPad unicode 4.5.5 (2405) English
Posted by: crimson | Date: 2010-12-15 03:18 | IP: IP Logged
Hi Jan:
There is a minor bug. After I updated to 2405, the the script items show twice in the submenu of Scripts menu. Please check it. Thx a lot.
best regards.
crimson
