You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.5 (2395) English
Goto Page: 1 2 3 4 5 6 7 Next
#1 PSPad unicode 4.5.5 (2395) English
Posted by: pspad | Date: 07/11/2010 21:34 | IP: IP Logged
Download links (2.1 MB):
pspad.cincura.net
Changes to 4.5.5 (2392)
Fixes
LOG resize with filetabs on the bottom
user highlighter - string highlighting
favourite panel - copy link doesn't copy log parser string
program title - fixed display of the file name
toolbar - fixed problem with nondefault font size after start
#2 Re: PSPad unicode 4.5.5 (2395) English
Posted by: papi | Date: 07/12/2010 09:55 | IP: IP Logged
Thank you for the bugfixes for my reports! It seems to work fine!!
#3 Re: PSPad unicode 4.5.5 (2395) English
Posted by: se7h | Date: 07/12/2010 12:11 | IP: IP Logged
excellent bugkiller release
p.s.: released a new version of HTML Tidy (EXE Version compiled 06 nov 2009)
Edited 1 time(s). Last edit at 07/12/2010 12:35 by se7h.
#4 Re: PSPad unicode 4.5.5 (2395) English
Posted by: carbonize | Date: 07/12/2010 20:00 | IP: IP Logged
Curious as to why you always put files such as PSPadShell.dll in the developer build cab files as they haven't been updated since 2009. Surely you could save a little bandwidth by only including updated files in the developer build cab file?
Carbonize
#5 Re: PSPad unicode 4.5.5 (2395) English
Posted by: pspad | Date: 07/12/2010 20:09 | IP: IP Logged
PSPad_Shell.DLL was updated. This is a reason, why i put it into developer builds.
You can use Unregister/register bat files if you are not able to do via PSpad program settings
#6 Re: PSPad unicode 4.5.5 (2395) English
Posted by: holger | Date: 07/15/2010 08:30 | IP: IP Logged
carbonize:
As I understand, the developer cabs include always all changes to the last stable release...
However:
My problem with the double-click for closing files seems still to cause PsPad to not register external modifikations of loaded Files. This is dangerous for me, because I cannot be sure, if I am developing the new or Old Version of File in PSPad.
BTW my prefered Settings:
CheckDocChanges=1
CheckDeleted=0
It's the same with CheckDeleted=1
Activating the autorefresh for a file reactivates the check for changed files.
Because a normal close of files not seems to have this effect, a little suggestion:
Maybe tabs could have a close-button on them?
Anyway, hope it will be fixed with next release!
#7 Re: PSPad unicode 4.5.5 (2395) English
Posted by: sheripg | Date: 07/16/2010 15:25 | IP: IP Logged
In previous versions I've used, if another app updated and saved a loaded file, PSPad prompted that the file had been changed and offered to reload it. That is not happening now. If the same file gets updated elsewhere, the PSPad version does not have the most recent version. Consequently previous file changes can be easily lost if the file gets updated in PSPad. Happened to me.
#8 Re: PSPad unicode 4.5.5 (2395) English
Posted by: sandrosilveira | Date: 07/20/2010 18:12 | IP: IP Logged
In 2395, PSPad don´t prompt that the files had been changed for me too, it is very important because our programmers edit files in a same directory.
#9 Re: PSPad unicode 4.5.5 (2395) English
Posted by: pspad | Date: 07/20/2010 19:48 | IP: IP Logged
I am not able to correct it without more details
#10 Re: PSPad unicode 4.5.5 (2395) English
Posted by: sandrosilveira | Date: 07/21/2010 00:03 | IP: IP Logged
See video in link: www.youtube.com if the resolution are bad say me how to send original video with 2.6MB to you.
