You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2325) English
#21 Re: PSPad unicode 4.5.4 (2325) English
Posted by: wjjchess | Date: 2008-07-27 13:55 | IP: IP Logged
thanks,
a new function:
In FileSearch, add RegExp
#22 Re: PSPad unicode 4.5.4 (2325) English
Posted by: pspad | Date: 2008-07-27 20:53 | IP: IP Logged
wjjchess:
thanks,
when a opened file is deleted,
it hope pspad can prompt "the file already delete"
PSpad tels you that file not found if you want to reload it.
#23 Re: PSPad unicode 4.5.4 (2325) English
Posted by: waysearcher | Date: 2008-07-28 08:09 | IP: IP Logged
thanks very much for this great Build. smiling smiley
Thanks for the secureFTP support grinning smiley and Slow file loading problem fixed.
Hope that I can help a bit - here are some Build's 2325 BUGs what we know of:
1) when I open a file using sFTP, the file's TAB doesn't show the small FTP icon on the bottom left part of the file TAB; when clicking through TABs, I click on the file's TAB again and it shows then.
2) When connected using sFTP, the file browse method is a bit weird - for example: when I am in the CACHE subdir and I go up, the pointer jumps to the first LISTed item (which is '..'). Maybe there should be a setting to act like other file managers - when we jump up the subdir, the pointer stays on the subdir. smiling smiley
3) When connected using sFTP, it would be great to have option to move the file list TABs (File, Size, Modified, Type, Rights) between each other - for example to have File and Modified TABs between each other. smoking smiley
4) When connected using sFTP, there should be and option to sort directories also by date (same as files).
5) Files on FTP sorted by 'Modified' TAB are sorted only by DATE, but not by DATE+TIME. When we also see the time, this is a bit confusing.
6) We re-open a file using File -> Recent option in menu and choose a file opened in FTP. The file is opened from local HDD (temporary folder) and not from FTP. When we save the file, it is not saved on FTP, but on local HDD. sad smiley
#24 Re: PSPad unicode 4.5.4 (2325) English
Posted by: venki | Date: 2008-07-29 10:45 | IP: IP Logged
VBR,
Thank you for the great help. There wasnt any pspad.ini but only pspad_MU.ini. Once I created a pspad.ini file everything seems to work fine. Now I am able to delete the characters using backspace and delete keys.
Thank you once again.
smiling smiley
#25 Re: PSPad unicode 4.5.4 (2325) English
Posted by: vbr | Date: 2008-07-29 11:36 | IP: IP Logged
venki:
VBR,
smiling smiley
I'm glad, it worked for you smiling smiley
PSPad.INI can be located in the PSPad folder or in the windows user account folder - depending on the setting
Program settings :: System integration: Multi user environment
But if the problem has gone, it seems, that you don't have to worry about this setting.
#26 Re: PSPad unicode 4.5.4 (2325) English
Posted by: poncho | Date: 2008-07-29 14:27 | IP: IP Logged
Still no symlink support? :(
>> forum.pspad.com
#27 Re: PSPad unicode 4.5.4 (2325) English
Posted by: pspad | Date: 2008-07-29 14:47 | IP: IP Logged
poncho:
>> forum.pspad.com
Nobody doesn't answer me the latest question in your thread
#28 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Eblis | Date: 2008-07-29 16:46 | IP: IP Logged
There seems to be a problem with the latest beta releases of PsPad. When PsPad starts up the toolbar size and position seems to be wrong; this is fixed by clicking on the toolbar - once i click on it it returns to the normal size and position.
This is how the toolbar looks when PsPad starts up:
And this is how the toolbar looks after i click on any empty space in it:
#29 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Skaurus | Date: 2008-07-31 12:24 | IP: IP Logged
Thank you very much for this build! Opening session with about twenty files, some of them quite big (~5-7k lines), and switching between them, all that with wrapping lines on - now it's not pain in the ass smiling smiley
#30 Re: PSPad unicode 4.5.4 (2325) English
Posted by: Thinker | Date: 2008-08-02 12:03 | IP: IP Logged
There is still an old bug with opening other project.
When I got one project opened and I click to open other one I always got the message box "Do you want to close current project?" - and:
1. I dont need that alert.
2. It does not work, click yes or clicking no works same - new project is opened.
