You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.4 (2315) English
Posted by: pspad | Date: 2008-03-30 17:51 | IP: IP Logged
Download links (1.7 MB):
pspad.siliconhill.cz
pspad.cincura.net
Changes to 4.5.4 (2314)
Known issues
Slow file loading
News
possibility to integrate PSPad into system via registry (Vista 64), now is possible to choose items in the menu
file PSPad_registry_clean.reg clears PSPad registry entries
SQR (Structured Query Reporter) Code explorer
Session - list of existing sessions on the save dialog
Corrections
Multimedia keys support - switched COT and COPY
Compiler saves file even it wasn't necessary
FTP client - exception when CHMOD was call in folder
FTP client cuts first chars of name on some servers
Posted by: StuartHemming | Date: 2008-03-31 07:10 | IP: IP Logged
Have just upgraded from 2303. Was delighted to see that there is now a C# code explorer. Sadly, it is confused by visual studio's "# region" directives.
And the start-up here, as has been reported by others, is horribly slow.
Stuart
Posted by: StuartHemming | Date: 2008-03-31 07:14 | IP: IP Logged
Whilst on the subject of the Code Explorer, it would be nice if it were possible to expand/collapse a node using the keyboard. For example, pressing right-arrow on a collapsed node should expand it down to the next level.
Stuart
Posted by: MrSpock | Date: 2008-03-31 17:26 | IP: IP Logged
Thank you for the new build. Two quick remarks:
1. The Cancel button and the caption of the Save Session dialog seem slightly wrong. The caption has an ampersand in it that I can't find in my lang.ini file, and the Cancel button is apparently labeled in Czech:
2. Settings -> System integration: Wouldn't it be better if the cascade PSPad context menu option were greyed out if the registry option (Vista) is chosen? It's not possible to cascade context menu entries from simple registry entries, AFAIK.
Posted by: pspad | Date: 2008-03-31 17:45 | IP: IP Logged
Thank you for the dialog info.
IMHO there is no possibility to build cascaded menu with Registry. I had it grayed this item, but then I removed it. I return it back
Posted by: hibou57 | Date: 2008-03-31 20:36 | IP: IP Logged
With the cession manager, when you are prompted to give a cession name to save the cession, the cancel button is labelled "Storno". I suppose this is České.
Posted by: Cucumber | Date: 2008-03-31 20:37 | IP: IP Logged
Howdy,
the save session feature is just as i imagined it. thanks for adding it in
Posted by: hibou57 | Date: 2008-03-31 21:32 | IP: IP Logged
Another detail about the cession manager : when I change the icon set via the application configuration, and switch from say gnome to office2003, then the cession manager icone disapears. It does not come back when I switch back to gnome, and does not come back as well when I close PSPad and re-launch it.
The button still work, but it look like as if it was not there, beceause there is no more icon to show it.
Edited 1 time(s). Last edit at 2008-03-31 21:32 by hibou57.
Posted by: MrSpock | Date: 2008-03-31 23:29 | IP: IP Logged
hibou57:Another detail about the cession manager : when I change the icon set via the application configuration, and switch from say gnome to office2003, then the cession manager icone disapears. It does not come back when I switch back to gnome, and does not come back as well when I close PSPad and re-launch it. [...]
Are you sure you have the new icon set bmp files installed to your PSPad\Skin folder? They were updated with build 2314, because of the new session functionality. (+1 additional icon.)
I can't reproduce your error. The session manager icon comes back for me as soon as I switch to an icon set that has it.
Posted by: Lolo | Date: 2008-04-01 08:51 | IP: IP Logged
There is a small problem with the title of this dialog box (in addition on the cancel button as mantionned above)
Thanks Jan for your hard work.
